586,110 active members*
3,418 visitors online*
Page 3 of 3 123
Results 41 to 44 of 44
  1. #41
    Mar 2007
    2083
    Re: Zero Touch Probe problem
    which speed control board do you have in your mill and how did you connect it to your C11G BOB ?
    does it look any thing like this ?
Name:	XMT-2360 sieg mill speed control.jpg
    with the FC250J board in my mini lathe for example
    Attachment 421522
    its possible to connect the 3 wires that originally connected to the C11G PWM to analogue converter
    to calibrate the maximum & minimum spindle speed you need to adjust the preset potentiometers that set the minimum and maximum speed using the original speed control potentiometer
    non linearity in the C11G PWM to analogue DC converter will more of a problem to correct
    John
  2. #42
    Aug 2016
    185
    Quote Originally Posted by john-100 View Post
    Attachment 421522
    John
    Yes I think mine is the 250 board as well. I connected the C11G to pins 1and 2. I did put a CNC to manual switch. So I am breaking the 0-12 volt and the ground. I used a complete separate 12 volts supply.
    I don't really understand what you mean about getting signal off the pot.
    How can I prove if the rpm index sensor is right
    Sent from my XT1635-01 using Tapatalk
  3. #43
    Mar 2007
    2083
    I am not sure why but in post 41
    "its possible to connect the 3 wires that originally connected to the C11G PWM to analogue converter"
    should of read -
    its possible to connect the 3 wires that originally connected to the FC250 speed control potentiometer terminals P1 , P2 & P3 to the C11G PWM to analogue converter
    provided the current taken by the C11G PWM to analogue converter is low enough
    the speed control terminal P1 can supply the +12V to the C11G
    with a FC250J / 230V board like this
    Attachment 421522
    or the 110V version
    when the speed control potentiometer is fully anti clockwise (counter clockwise )
    the DC voltage from the speed control potentiometer terminal P2 may not turn down to zero with respect to terminal P3
    Also the maximum voltage when the potentiometer is fully clockwise may not be exactly 12V
    as you would expect with a 12V zenner diode regulating the 12V supply !
    what is the maximum and minimum speeds displayed by mach 3 and your tachometer ?
    John
    PS
    in mach you can adjust the pulley ratio to change the speed mach 3 displays without changing the actual motor speed
  4. #44
    Aug 2016
    185
    should of read -
    or the 110V version
    John
    PS
    I have the Little Machine Shop beltdrive installed maybe my ratio is off,,,
Page 3 of 3 123
  1. Touch Probe
    By Babba in forum Syil Products
    Last Post: 03-11-2022, 04:36 PM
  2. 3D touch probe
    By bschwand in forum MetalWork Discussion
    Last Post: 12-26-2013, 10:06 PM
  3. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  4. Touch probe
    By kolias in forum Mach Software (ArtSoft software)
    Last Post: 09-08-2012, 11:16 PM
  5. Heidenhain iTNC530 touch probe problem
    By jan.van.gent in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-15-2012, 12:31 AM
