I have a new CNC Mogul system that I want to use for plasma cutting purposes but I have no idea how to connect everything to work together. I have a
Ebay bought Accurate Tools plasma torch ATPC52: New 50 Amp Air Plasma Cutter DC Inverter 50A Cutting | eBay
CNC Mogul system: CNC Mogul
Proma Compact THC (torch height controller): Proffessional Compact CNC Plasma THC Controller Torch Height Control | eBay
I use the Mach 3 program
Both the Mogul and the Plasma work seperately but I want to connect everything together. That's where I need your help. This is beyond my ability and I can't find anyone locally to do it. I'm located in Waterford, Michigan. If someone is local and could come by and hook this stuff up, I'd be more than happy to pay or if someone can write some specific directions would be fantastic...and I'd also pay. Tired of having this stuff sitting around collecting dust. I've already built the water table and use it for hand-held plasma cutting.
The plasma is one that has to touch the metal to generate an arc.
I'll need wiring info and program info. HELP! HELP! HELP! If you have a Kawasaki Concours 14, I'd be more than happy to supply you with parts in-exchange for help.
