586,817 active members*
8,096 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Sharp corner lettering
    Mar 2011
    24
    Unhappy Sharp corner lettering
    Looking to get sharp corners in lettering using a vtool in bobcad v25
    When using for example a courier font all inside corners take on the
    radius of the bit.
    Can this be done and how do you proceed?
    Aug 2012
    621
    Do you have BobArt? You'll need the Vcarving toolpath for sharp corners. After that, it's easy. I'll make a video.
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    Jun 2012
    393
    another video hurray . LoL is this about a boat JK. I cannot wait for a vid on lettering. I want to get into raised lettering. If you could add this to your list.
    thank You
    Don
    The time has come the woodworker said to speak of many things. 0f routers and Wood , chips and paints and stains and CNC and other things.
    Aug 2012
    621
    Here's a quick one on Vcarving text.
    I actually made some progress on the boat last night... For raised lettering, I'd draw some geometry, (say, a rectangle), just outside the text, then Vcarve with that geometry selected. The letters would get cut as raised embossments, and the bottom would get pocketed flat in the Vcarve. Then you could use a pocket with an inner Boundary to mill out rest of the stock to the new base surface..
    Luke
  1. Lettering
    By ACunningham in forum MetalWork Discussion
    Last Post: 04-22-2013, 06:39 PM
  2. How to make a sharp corner on a mill?
    By zaebis in forum MetalWork Discussion
    Last Post: 09-02-2009, 07:57 PM
  3. Faceplate lettering.
    By moldmker in forum CNC Machine Related Electronics
    Last Post: 08-07-2008, 06:16 PM
  4. Raised lettering, How ???
    By Mr. LocoMartin in forum BobCad-Cam
    Last Post: 03-29-2008, 07:10 PM
  5. Making a sharp inside corner?
    By Docmani in forum MetalWork Discussion
    Last Post: 11-14-2005, 06:26 PM
