Torus Pro log
Today I finalized the order for:
- Torus Pro Servo Edition
- the upgraded stand
- power draw bar
- the built in control computer
Should be shipping in 2 weeks. Here are the answers to a few questions I had, just in case anyone else is looking:
- the minimum distance from spindle to table is 120mm.
- the spacing between T-slots on the table is 2.4".
- The electrical requirement is a 20A 220V single phase breaker. The end is just a bare end so you can either put a connector on it or run it right into a junction box. Also found out that the mill will function properly on the older style 220 wiring using 3 conductors (the neutral and ground are tied together). I will be putting a 20A 4 prong connector on so I can plug it right into my outlet.
- you can use a TC style tap with the mill out of the box, but the resistor breaking upgrade ($89) is recommended. I didn't get the upgrade and will be doing tapping as a secondary op on the pneumatic tapping arm we have.
Nate
Fine Line Automation
Home - Fine Line Automation
www.finelineautomation.com
