586,047 active members*
3,903 visitors online*
Results 1 to 7 of 7
    Aug 2011
    27
    resetting a ST-28 MAZAK
    Hello. Anyone have the procedure for resetting a ST-28 MAZAK Lathe with Mazatrol T32 plus system. We did a reboot, after reboot the machine, automatic operation mode the program starts running, the tool moves, then the tool stops, the start button is pressed but does not obey, no alarm goes off. thanks
    Jan 2014
    7
    Hello,
    I have the procedure for resetting this MAZAK. When you want you can write me an PN and i will give you a tutorial about it It's not very hard.
    Regards
    Mark
    Do it, dont try it.
    Aug 2011
    27
    Hello Kommanu, How do I contact you to obtain the reset procedure? thanks
    Oct 2003
    321
    T32 plus?
    T32 oder T-plus its different.
    Best regards
    Mazak-user
    Gesendet von meinem PAP5000DUO mit Tapatalk
    Aug 2011
    27
    is t32!!
    Oct 2003
    321
    give me your mail. I will send you the procedure.
    Best regards
    Mazak-user
    Aug 2011
    27
    my email is [email protected]
    thanks
  1. Resetting Machine Zero
    By mcmachining in forum G-Code Programing
    Last Post: 08-24-2009, 04:38 PM
  2. SL 15 Parameter resetting
    By MILLMANM in forum Mori Seiki lathes
    Last Post: 10-08-2008, 04:01 PM
  3. Resetting X0 Y0 Z0.
    By Witsenburg in forum Mach Software (ArtSoft software)
    Last Post: 06-05-2007, 03:39 PM
  4. Resetting the top view ?
    By altered in forum Mastercam
    Last Post: 03-17-2007, 10:03 PM
  5. Zero location resetting mid-run
    By esmiller in forum Machines running Mach Software
    Last Post: 03-03-2006, 09:00 PM
