586,068 active members*
4,458 visitors online*
    May 2008
    7
    Heidenhain TNC 355 BLOCKWISE PROBLEM
    HI FOR ALL CNCZONE MEMBER
    I HAVE A PROBLEM WITH MY HEIDENHAIN TNC 355. WHEN I TRY TO CONFIGURE MY MACHINE TO BLOCKWISE TRANSMISSION. I CHANGE THE MP 223= 1 LIKE THIS
    Attachment 219366
    AFTER THIS WHEN I TRY TO SEND FILE WITH CIMCO . THE MACHINE BUG "I CAN'T DO ANY OPERATION".
    I MUST REBOOT MY MACHINE TO WORK AGAIN.
    PLZ HELP ME HOW CAN I SEND BLOCKWISE FILE IN MY MACHINE?
    I USE THIS CABLE
    Attachment 219368
    "SORRY FOR MY POOR ENGLISH".
    May 2004
    402
    Go to the Heidenhain.de web site and download TNCRemo - it's a free download. Use the included TNCServer program. It works well both for uploading, downloading and blockwise 'drip feeding'
    I also have a TNC355 - I use TNCServer (in fact I was using it this afternoon!) - it works - it's reliable.
    Best of luck,
    Andrew
    Andrew Mawson
    East Sussex, UK
    May 2008
    7
    Quote Originally Posted by awemawson View Post
    Best of luck,
    Andrew
    thanks awemawson , i will try it and take y inforormed
    Dec 2008
    24
    Re: Heidenhain TNC 355 BLOCKWISE PROBLEM
    The cable you are using does not work, have tried it
    May 2008
    7
    Hi Blakey235
    this cable work fine . i send and receive data from PC to my CNC.
    but the maximum of block who can i send is 600.
  1. Heidenhain ERO 115 encoder problem
    By AlMol in forum Bridgeport / Hardinge Mills
    Last Post: 12-02-2013, 08:32 PM
  2. Problem with heidenhain 426
    By monika13361 in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2012, 02:42 PM
  3. Blockwise transfer to TNC355, max amount of blocks?
    By Oviksnc in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2011, 07:25 AM
  4. Blockwise transfer,drip feed on Tnc 2500.
    By Paul cs in forum Bridgeport / Hardinge Mills
    Last Post: 09-02-2008, 02:45 PM
  5. Heidenhain TNC 145 problem
    By emimec.19@btint in forum Bridgeport / Hardinge Mills
    Last Post: 06-23-2008, 06:50 PM
