I was busy with a strip and rebuild of a slant bed turning center and got as far as removing the turret. Time is catching up fast and i would have to make money on it or go bust. The main reason for the strip was that i suspect the lubricant on the z axis is inadequit as the slide always seem dry(apart from coolant). Is there any shortcuts for unblocking the lube channels in the castings?? I was thinking maybe high pressure or something that can dissolve/soften the blockages.
I have rebuilt an old capstan before and there all the channels was clogged up solid(i suspect someting similar here)
My concerns are that if i manage to force the blockage out it would still be trapped under the saddle where it would only cause another blockage.
Does anyone here know the correct procedure for doing the geometrical correction on a slant bed lathe???
Machine is a Victor TNS2 with fanuc 10T 1985 model and 10" power chuck
