586,596 active members*
2,827 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Power tapping and best way to secure tap and KBB 125 power compenstation.
    Jun 2010
    28
    Have G0704 and am having troubles power tapping. The standard R8 collets I have been using are allowing the tap to spin within the collet, no matter how much I tighten them. Is there a better way and an economical one at that to secure these little buggers?
    Also, anyone with an upgraded KBB board? Need some guidance adjusting the pots to maintain speed, torque. Not very fluent in electrical stuff.
    -Dave
    Feb 2006
    7063
    You're doing *rigid* tapping with a DC motor spindle? You *really* should be using a tension/compression tap holder, if not a full tapping head....
    Regards,
    Ray L.
    Quote Originally Posted by RX-Heven View Post
    When I did some power tapping the drill chuck worked great for 3/8 taps in steel.
    I did the same for years at work with our bridgeports.
    There are instructions in the KB manuals for adjusting the pots.
    Hoss
    G0704 Power Tapping - YouTube
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  1. Power tapping without reversible drill press
    By Laurent_parti in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2016, 03:16 PM
  2. Dedicated **BENCHTOP** CNC Power Tapping Fixture
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 08-11-2012, 07:30 PM
  3. Replies: 0
    Last Post: 11-04-2011, 07:51 PM
  4. Replies: 5
    Last Post: 10-13-2010, 03:28 PM
