586,461 active members*
4,925 visitors online*
Results 1 to 12 of 12
    Feb 2012
    6
    56 alarm emergency stop external
    Hi, i need some help please. i have a mazak vmc it's a VQC-15/40 with mazatrol M-32 control. it was working fine but a few days ago it started to show this alarm message "56 Y EMERGENCY STOP (EXTERNAL)". I reset the machine worked 30 min and the alarm lit up again. lately i have this alarm message since i turn it on. I took some pictures included in the pdf file i attached. Any suggestions are welcome. sorry for my bad english i hope i was able to comunicate my problem and someone can help. Thanks. :cheers:
    Oct 2003
    321
    you have the problem und the Y-axias servo. This show you 55 : overload.
    The one on the left side show you : 56 ( it means I have no problem )
    The one on the reight side: E7 emergency stop.
    Also E7 on the spindlecontroller FR-SF ....
    You must repair the MR-S1- ???? for the Y-axis.
    best regards
    mazak-user
    Servotek Service.com - Willkommen
    Feb 2012
    6
    Hi, Thanks for your help. Do you have an idea where to look for the problem? or how to test the driver? i cleaned the conectors of the servos and the problem was diminished but not solved. that makes me think that maybe there is a problem in the wiring from the driver to the servo. do this have some logic to you?
    Oct 2003
    321
    You get the alarm immediate when you turn on the machine, or later when you drive y-axis.
    Best regards
    Mazak-user
    Gesendet von meinem PAP5000DUO mit Tapatalk
    Feb 2012
    6
    Hi, i get the alarm immediately when i turn on the machine. that alarm message is the first thing i see when the control screen is on. somebody told me to unplugged the UVW wires in the drive, turn on the machine and see if the alarm message was gone, so i did it. but the alarm did not turn off.
    i appreciate your help. take care.
    Feb 2012
    6
    Hi, just updating. i swap the drivers boards of Y and Z and the alarm change from Y as it was from the start to Z. i think that proof the problem is the driver board. do you thing the board can be repaired or should be replaced?
    Thanks. good day.
    Oct 2003
    321
    Quote Originally Posted by s-kin View Post
    Thanks. good day.
    Hallo,
    have you solved the problem, and what was the reason for alarm 55?
    best regards
    mazak-user
    Feb 2012
    6
    Hi. No i didn't solve the problem the machine is still not working. two electronics technicians checked the driver board but didn't find the problem. this is really frustrating any suggestions would be appreciated.
    best regards.
    Oct 2003
    321
    make a bridge from B to R at the connection board of the MR-S1 ..., an try it!
    best regards
    mazak-user
    Feb 2012
    6
    Quote Originally Posted by mazak-user View Post
    best regards
    mazak-user
    Hi, i did the bridge but nothing change.
    Oct 2003
    321
    Re: 56 alarm emergency stop external
    What about your problem with alarm 55?
    Best regards
    mazak-user
    Nov 2010
    21
    "56 y emergency stop (external)"
    Best regards
    mazak-user
    Hi I am also facing same alarm "56 Y EMERGENCY STOP (EXTERNAL)" .how did you solve the problem Pleaseeeeeeeeeeeee.
  1. ALARM 20 NMI EMERGENCY STOP.
    By GPena in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-13-2022, 02:48 PM
  2. NMI 20 Emergency Stop Alarm
    By pcreek in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-17-2019, 01:52 PM
  3. 058 emergency stop (external) Alarm
    By gearmachinist in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-02-2012, 06:55 PM
  4. Alarm 128 QT-8 Emergency stop
    By grabolo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-22-2009, 07:24 PM
  5. M2 External Outputs - Feed Hold, Emergency Stop
    By nlh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-22-2009, 02:49 PM
