586,032 active members*
2,764 visitors online*
    How do I reset SolidCAM defaults
    SO...........
    All of my SolidCAM learning has been through the video tutorials in YouTube and SolidCAM professor. I've been exploring the iMachining toolpaths and have been experimenting with feeds and speeds. The post processor I use in Mach3, which runs the CNC router table, is not in the SolidCAM package. However, using the Fanuc post-processor translates into Mach3 almost seamlessly. Mach3 will process the g-code generated from the Fanuc settings in creating toolpaths. In my exploration of SolidCAM, I've created a tool library for the cutters I have in my inventory. Up to this point, all the "toolpath-ing" I've been doing has worked as I've been instructed in the tutorial videos. So, I ventured into changing some of the numbers in the Machine ID for spindle RPM and the other feed settings for XY and Z to, hopefully, create a machine profile for my CNC router. I "noodled around" with changing settings in the HAAS machine ID as well as adding a material to the material database and tried to create a new machine ID. Eventually, my iMachining operations began to give me dialogue boxes stating the "RPM is too large" and the "feed is to large"....eventually, the iMachine Wizard wouldn't even function on some of the 2D iMachining operations I was trying to create.
    How do I restore the SolidCAM defaults and get back to square one?
    Feb 2013
    49
    just overwrite the files if you have a back-up of your vmid,prp, and gpp before playing around with them
    Mar 2011
    68
    You can reset all settings from solidcam from START->RUN->REGEDIT->HKEY_CURRENT_USER->Software->and delete Solidcam entryes.
    Also if you want to restore your postprocessors data's, you must delete SolidCam and reinstal, also it can be possible to rename for safety the GPPTOOL folder and repair Solidcam.
  1. defaults
    By KS Cowboy in forum Visual Mill
    Last Post: 12-07-2011, 05:21 PM
  2. Setting some defaults
    By OCNC in forum MadCAM
    Last Post: 06-14-2011, 12:45 AM
  3. X4 Operation Defaults
    By WingNutz in forum Mastercam
    Last Post: 12-31-2009, 04:29 PM
  4. Changing defaults in v9
    By juxtoposed in forum Mastercam
    Last Post: 12-09-2009, 03:37 AM
  5. Rhino_Tools_Options Defaults?
    By robinsoncr in forum Rhino 3D
    Last Post: 06-12-2006, 05:07 PM
