Originally Posted by
NC Cams
Shizzlemah:
In a Motion Science servo amp like that in an Ezpath or Eztrak, torque is hard limited by a current sense circuit in the servo amp.
There is NOT a velocity feedback in these systems, only a position feed back from the motor directly to the PC. Current/torque is limited by the amp itself.
This refers to current limit, I believe arr5ow was refering to torque control, if you do a search for transconductance amplifier it should give a clearer explanation, this is current out directly related to a voltage in,
A transconductance amplifier outputs a current (torque) proportional to its input voltage.
Al.
Albert E.
