Originally Posted by
BurrMan
Kindof hard to say "why". It has to do with it's construction/command used"..... To start with, the 2 curves that meet at that point, aren't tangent. So doing a simple sweep would create a nice surface, but there would be a visible seam there, and someone may tend to want to start to use commands like matchsrf or something, which would start to produce odd bulges like that. Or improper use of network.
Try network those 4 edges with The 2 rails set as loose, or position with the lower radius set to tangency or curvature, and the top one as position...
If your trying to get those 3 edges to blend together like that, you'll have to fix the tangency of the generator curves meeting point, or you will always get buggard up surfaces.
solution
start again
painsteaking but effective
CHOCLATE? THIS IS DOODOO BABY!
