586,070 active members*
3,629 visitors online*
IndustryArena Forum > CAM Software > PowerMILL > Post Processor for Mach 3
    Nov 2010
    10
    I installed the Fanuc Post Processor form PowerMill. It seems to generate codes OK., but i get a funny move upon startup after a G43 Code and the spindle gets lost on the X and Y axes on a tool change. Am I using the wrong post? Here are the relevant Sections from the code. Look at N 320 and N37340:
    FIRST PROBLEM (at program start)
    N210 ( STRATEGY USED : Offset_area_clear )
    N220 ( TOOLPATH WP : Top )
    N230 ( ================= )
    N240 ( TOOL TYPE : ENDMILL )
    N250 ( TOOL NAME : 1 )
    N260 ( TOOL DIA.: 0.1875 & TIP RAD.: 0 & LENGTH : 0.9375 )
    N270 T1 M6
    N280 G54 G90
    N290 S4000 M3
    N300 M8
    N310 G0 X-.0009 Y-.2066
    N320 G43 Z.4375 H1
    N330 X-.0484 Y-.2132
    N340 Z-.1825
    N350 G1 Z-.405F2
    N360 X-.0465 Y-.2257F4
    SECOND PROBLEM (at tool Change)
    N137230 G0Z.6
    N137240 M9
    N137250 Z.8925
    N137260 X-.6571 Y.4806
    N137270 ( ================= )
    N137280 ( TOOLPATH : 2 )
    N137290 ( STRATEGY USED : Surface_machine )
    N137300 ( TOOLPATH WP : 1 )
    N137310 ( ================= )
    N137320 G91 G28 Z0
    N137330 G49 H0
    N137340 G28 X-.6571 Y.4806
    N137350 ( TOOL TYPE : BALLNOSED )
    N137360 ( TOOL NAME : 2 )
    N137370 ( TOOL DIA.: 0.5 & TIP RAD.: 0.25 )
    N137380 T2 M6
    N137390 G54 G90
    N137400 S2700 M3
    N137410 M8
    N137420 G0 X-.6571 Y.4806
    Oct 2008
    13
    Mach3 postprocessor
    You can try this opt file
    Attached Files Attached Files
  1. post processor for mach 3?
    By njitnjau in forum EdgeCam
    Last Post: 09-26-2019, 04:28 AM
  2. Mach 3 Post Processor goes where????
    By USMCCNC in forum G-Code Programing
    Last Post: 06-15-2010, 06:17 PM
  3. Mach 2 Mach 3 Post Processor
    By IntarisiaQ4 in forum Australia, New Zealand Club House
    Last Post: 10-17-2009, 11:50 PM
  4. re post processor v21 mach 3
    By woffler in forum BobCad-Cam
    Last Post: 06-06-2008, 03:49 AM
  5. VM 3.0 Post Processor for Mach 3 OR 2
    By TCSpooner in forum Visual Mill
    Last Post: 12-28-2007, 03:55 AM
