586,080 active members*
3,622 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Setting Rounding Endmill
Results 1 to 9 of 9
    May 2004
    402
    Not actually used rounding end mills before, but set one up in the machine today and put it in my FeatureCAM tool crib and did a trial rounding of a square boss. Tool showed up on the FeatureCAM virtual screen as cutting a nice rounded edge as I wanted, but the tool path took my physical tool, whipped it round the boss at a height with the end at Z=0 so no cutting.
    Setting tool height I'd done exactly what I do for all the tools - use a Z height touch off sensor on the end of the tool.
    Now the Round feature dialogue box lets you set an X,Y,Z offset, and by setting Z = -5.00 mm (it's a 5 mm radius rounding end mill), Now the virtual screen shows the rounding 5 mm lower, so wrong, but the physical tool cuts in the right place.
    I can overcome this by fiddling my tool length by reducing it by the radius (5 mm) of the rounding cutter, but what should I be doing, here - what do you do to touch off a rounding end mill ?
    Andrew Mawson
    East Sussex, UK
    238
    Touch off Zero at tip of cutter, and then minus Z half of your radius in Z and same for X or Y. If I remember correctly that is. Been a long time.
    238
    Wait a minute, that made no sense.
    May 2004
    402
    70 plus FeatureCAM fans and NONE of you knew this :violin:
    Well eventually I found an obscure reference to this in the FeatureCAM help file. When setting Edge Rounding cutter the touch off point is the upper part of the curve. This obviously is pretty impossible practically, so I will continue to touch off as normal on the lowest part, then add the cutter radius to the tool length offset in my control. If you think about it this achieves the same thing, as from bottom to top of the radius of the cutter IS one radius :banana:
    Andrew Mawson
    East Sussex, UK
    238
    Well it's kind of what I suggested. I'm sure their could be a million users on this forum, and if no one has a need for a rounding endmill, and the help file being pretty vague as is, then you are forced to come up with your own solution. Personally, I do what you do. It works. Lately I've been doing most of the rounds on sides with ball mill. Yes It certainly isn't as efficient as a rounding endmill, but it also works and very well I might ad. It just takes a lot longer.
    Glad you came up with a solution that works for you.
    Jul 2010
    369
    Here ya go.
    You can choose to touch off at shoulder or not.
    It is more easy for the operator to not touch off at the shoulder
    :cheers:
    May 2004
    402
    Loverly jubbly
    However my V13 doesn't have that tick box !!!!
    Andrew Mawson
    East Sussex, UK
    Jul 2010
    369
    DOH!
    I'm sorry :wee:
    May 2004
    402
    Delcam obviously saw the error of their ways and added the box. I was surprised that the earlier version I have didn't use the end of the tool and calculate the cutting position, as not only is it a very simple calculation, it brings the rounding cutter into line with all the other tools we use and touch off on the end !
    Andrew Mawson
    East Sussex, UK
  1. rounding over whilest on the cnc bed
    By zac123 in forum WoodWorking Topics
    Last Post: 04-11-2012, 11:39 PM
  2. carbide corner rounding endmill
    By samu in forum MetalWork Discussion
    Last Post: 09-19-2009, 02:12 AM
  3. What is Your #85 Setting (Max Corner Rounding)
    By Rocko1 in forum Haas Mills
    Last Post: 10-28-2007, 07:54 PM
  4. Corner Rounding on TM1
    By JHamdan78 in forum Haas Mills
    Last Post: 08-14-2007, 09:43 AM
  5. corner rounding
    By sundy58 in forum FeatureCAM CAD/CAM
    Last Post: 11-23-2006, 03:54 AM
