This is a link to a zip file that contains gcodein.fas and a readme.txt file.
You can use it to read a cnc mill file into Autocad. I also have a lathe version I will post on my website later.
intergate.com/~wjb1/wjbzone/autocad/gcodein.zip
Bill
Bill
What does that do?
You can read a cnc gcode file into an Autocad layer.
1. Launch your Autocad application.
2. Use appload to load the gcodein.fas.
3. Type gcodein at the Autocad command line.
4. Browse locate your cnc gcode file.
The cnc file is read into the current Autocad layer as lines and arcs.
You can step one line at a time or set the number of lines to step.
I use to verify my code before I run it on my machine.
Bill
OK, thanks I understand now.
It would be nice if the step number stayed the same so you could just hit enter or right click to step through, right now I had to type the step amount each time. Other than that, it seems to work pretty good.
"It would be nice if the step number stayed the same so you could just hit enter..."
Gerry,
That's the way it works. At each pause in execution, the default step number is displayed at the beginning of the command line.
i.e.
if the default is 1 the command line reads:
"1 Enter Step Increment (0 to Continue)"
if the default is 20 the command line reads:
"20 Enter Step Increment (0 to Continue)"
The number at the beginning of the line (the 1 or the 20 shown above) is the default number of steps if you just hit the enter key.
The only time you should have to type a number is when you want to change the default (can be any positive number).
Type a 0 (zero) to run without a pause.
Let me know that is not working for you.
I'll try to make that more obvious in next revision.
Bill
My mistake, it does seem to work properly. One thing I noticed with code generated from MeshCAM, It crashed if the first move was:
G1 Z0.00 F10.00
I'm guessing it didn't have a place to start with just the Z-value in the first line.
You got me on that one. Looks like a G0 or G1 with a zero move at the start of the program is a problem. I'll get that fixed as soon as I have a chance. Got to to some painting first today.
Will post again as soon as it's fixed.
Bill
I got the program updated. Fixed the problem with the first move.
The link on the first post of this thread is the current version.
Bill
Can you use this with AutoCAD 14 and if so, how? I've never run across a .fas file before.
Sorry mrainey,
I don't believe a .fas file can be read into Autocad 14. The lisp routine uses several visual lisp functions. These are supported by Autocad 2000 and above.
Bill
Another update to the gcodein program has been posted. I also put the lathe version (gcodeinL) on my website. (in the Autocad section)
Bill
BIll, I found a bug in you're program. I'm writing a VBA program to export G-code right from AutoCAD and I was using you're program to test the output. I didn't look into it too much, but I think you're not handling G2 or G3 correctly for arcs greater than 180°. If you try it with the following code, the center of the G3 is not what's specified.
G1 X-5.6406 Y-11.7226 Z0.2500
G1 X-2.8821 Y-8.2443 Z0.2500
G3 X-5.1488 Y-8.3814 I-1.1948 J0.9476
G1 X-4.3407 Y-9.1800 Z0.2500
This is incremental I and J, btw. I loaded the code into the KCAM demo and it displayed fine. Just thought I'd let you know.
Gerry,
Got that one fixed. It now will handle a arc greater then 180 degrees using I and J.
Let me know if you find anything else.
Bill
I modifed the gcodein file again. Did not change the revision number.
Had a problem with cw arcs using I and J after fixing the previous error.
(current version is modified 12/29/2003 3:27pm)
Bill.
Bill, one thing you should do here is get the value of OSMODE (Osnaps) and reset it when you're done. Every time I run this it turns off my snaps
One other thing, anything over 999 you're not drawing in the right place I noticed. Is this a bug or intentional. I found this out by running a rather large drawing through my exporter, and reading it in with yours. (It's kind of neat watching it duplicate my drawing while I watch).
Gerry,
I do save and restore the osmode in gcodein. I checked it out and it resets my osnap to the original settings.
I think I know what the problem is with the 999. I'll try to get that bug fixed tomorrow. I never ran into the limit with my scale of drawing (in inches).
Bill.
One thing I want to figure out is how to make the open file dialogue box default to the autocad drawing folder.
Got rev 1f posted.
Release 1f 1-30-04
changed open file dialog box to default to current drawing directory
change to allow coordinate values greater than 999
change to reset color to previous value
change method of restoring osnap
I did not try the 999 coord. fix, let me know if it's working.
Bill
You might be able to use the PROJECTNAME variable to help with this. I've never used it, just found it in a quick look through the help file. As for the Osnaps, I've never really looked into it, I just noticed that everytime I've played around with your Gcodein My snaps always ended up turned off. I just use something like thisOne thing I want to figure out is how to make the open file dialogue box default to the autocad drawing folder
at the beginning of your code
(setq osold (getvar osmode))
at the end of your code
(setvar osmode osold)
I used the dwgprefix (read only) variable to get the path. The file dialog box is now defaults to the current active drawing directory.
For the osnap, I had been using (command "osmode" osold)
I changed it to:
(setq osold (getvar "osmode"))
(setvar "osmode" osold)
The problem with the coords had to do with the way I parsed through each line. I stopped looking after 7 digits. I set it up to 12 digits now.
Bill
