586,094 active members*
3,807 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Setting parameters for RDIF in Okuma LC30 OSP5000L
Results 1 to 6 of 6
    Hi!
    Is it possible to change the value of RDIF parameter for each axis (XA, ZA, XB, ZB)?
    I need to find the problem in ballscrew. In this case I want to manualy change the RDIF value to get the alarm error during the axis moving.
    The lathe will work in test mode (withowt detail) until the error appears.
    (RDIF it is the difference between the actual position and the calculated position).
    Apr 2009
    1262
    RDIF is only a math calcualtion of the RAPA and RCON so it is not adjustable. You can adjust the backlash parameter in the SYSTEM PARAMETER screen in order to determine how much backlash a screw might have. IF your RDIF value is tripping an alarm, it is because your axis is jammed usually or some other mechanical binding in covers, gibbs, etc..
    Best regards,
    I know about calculating this parameter. I need to make border in -range and +range. For example, the preset value is 16842/2 mkm. If the range of RDIF is more then this value - the 100 error appears. I want to decrease the range - make the drive more sensitive.
    Apr 2009
    1262
    I'm curious why. Is this something you can use torque limit or torque skip for? Drive sensitivity is not really changed, only distance travelled before fault.
    Best regards,
    Yes, I need to change the distance to fault. Now it as 8 mm, I need to decrease it till 1 mm.
    Feb 2009
    6028
    Why not just use DROOP control then, that will "tighten" up the axis more than Rdif.
  1. OKUMA LC30
    By w.toman in forum Okuma
    Last Post: 02-03-2013, 12:34 AM
  2. OKUMA LC30
    By w.toman in forum Want To Buy...Need help!
    Last Post: 01-31-2013, 04:59 PM
  3. okuma osp5000l
    By sanbad in forum Okuma
    Last Post: 11-20-2012, 07:08 AM
  4. Okuma LC30 OSP3000 lathe Manuals
    By bbarber80 in forum Machinery Manuals / Brochures
    Last Post: 09-22-2012, 07:31 AM
  5. Okuma LC30-can turret feeding when spindle is stopped?
    By fitzpatrick2362 in forum Uncategorised MetalWorking Machines
    Last Post: 03-24-2010, 06:12 PM
