586,076 active members*
3,775 visitors online*
    Aug 2004
    218
    32 surface finish
    Hi guys
    I have a print that states 32 surface finish, can one of you tell me what this looks like.
    I should have mentioned the parts will be turned from 304 SS.
    Is it possible to turn this finish
    Oct 2003
    263
    Very slick - depending on the material, it can be challenging to hold a 32 finish on a production run of turned or milled parts.
    Software For Metalworking
    http://closetolerancesoftware.com
    Dec 2005
    49
    Holding a 32 finish in 304 is not hard. we routinely hold 12 -16 in CRES. the trick is to have the right nose radius and the speeds and feeds to match. In general the bigger the nose radius and the slower the feed, the better the finish.
    That holds true up to certain point. if you are taking a big cut with big radius and too slow a feed, you will stall the machine.
    so take a light cut (.005) with a rigid tool with a .012 or bigger radius with slow feed (you'll need to play around ) and you should be fine.
    Tinmuk
    Any problem can be solved by the proper application of heat!
    Dec 2005
    3319
    Here are some references to use as a visual comparison:
    The ID of the big end of an automotive connecting rod (where the bearing fits) is roughly 40~60 micro inch (which is what I suspect you're units are).
    The OD finish of a piston pin is roughly 6~10 micro inch.
    The freshly honed finish of a cylinder bore is a bit rougher than what you're looking for but not much PROVIDING it is not a mirror finish like some guys use for racing.
    If you have a record groove, it is WAY too rough,
    If it is a mirror, it is WAY too smooth.
    May 2006
    34
    There is a formula from Mitsubishi for calculating the surface finish you would get that I use when turning. The link to the page is below. 32 is not a problem.
    Link for Formula:
    http://www.mitsubishicarbide.net/mmu...n/formula1.htm
