Originally Posted by
lapoltba
So I take it this part of the forum doesn't get much traffic.... I figured there would be at least a few questions about the positioning stage I'm using.
Anyway, just a little update. I got my spindle yesterday and the VFD last week as seen in the video. I decided to splurge and order from Ugracnc. I got the 0.8kw air cooled square spindle. First impressions yesterday was that it is a very solid spindle for the price. Fit and finish is excellent and it seems like some thought was put into the unit. I measured runout of the taper with a 0.00005" test indicator and it didn't even wiggle. I also put a brand new 1/4" collet and carbide end mill in and checked again with the same result. I'm guessing it's somewhere less than 25 millionths, simply amazing.
Tonight I soldered the connector and wired it to the VFD. Once I did a factory reset on the drive and set the critical parameters before doing an auto-tune, I had the motor running with no issues. I took another 30 minutes or so playing with the accel/decel times, braking, and current limits and I am very happy with the result. It spins up from 0-24000 RPM in ~5s and back to a stop in about 8s. I plan to get a braking resistor to help with the braking a bit, but it works fine as is.
Can't wait to get it mounted up and do some cutting.
