586,617 active members*
2,296 visitors online*
Thread: Servos
Results 1 to 6 of 6
    6855
    Servos
    Does mach support servo's?
    Jun 2003
    2103
    Paul as long as the servos will take step and direction. I think it will do the pwm motors as well but I am not sure.
    turmite
    No greater love can a man have than this, that he give his life for a friend.
    Hi:
    It will drive Step/Dir. But it will only drive a PWM spindle speed control..
    Art
    www.gearotic.com
    Art Fenerty
    Jun 2003
    453
    I'm not sure if my servos take step and direction, all they have is a positive and negative terminal on the body and the wiring for the encoder at the end. My guess is that it can only handle PWM. I was under the impression that boards like Rutex R990h could take the step and direction and convert it to PWM. Dose this mean that my motors (Electrocraft E543 dc brush motors) are not compatible with Mach2?
    Splint
    Apr 2003
    1079
    Splint, you will have to have servo drives between your PC and motors such as Gecko's or the Rutex drives. This is true of all motors.
    Nov 2003
    299
    Originally posted by Art Fenerty
    Hi:
    ....drive a PWM spindle speed control..
    Art
    What's a PWM spindle speed control? An example?
  1. Servos pausing and starting
    By InsaneEPP in forum Servo Drives
    Last Post: 03-16-2005, 03:45 AM
  2. Replacement servos, not sure what I need..
    By yukonho in forum Servo Motors / Drives
    Last Post: 01-03-2005, 11:56 PM
  3. Brushles DC Servos works in CNC?
    By Yepez in forum Servo Motors / Drives
    Last Post: 12-05-2004, 07:02 AM
  4. Replies: 6
    Last Post: 03-06-2004, 05:11 AM
  5. steppers vs. servos
    By twombo in forum DNC Problems and Solutions
    Last Post: 06-10-2003, 08:43 PM
