586,106 active members*
3,049 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Overfilled centurion 6 memory
Results 1 to 3 of 3
    Nov 2008
    47
    I over filled the memory on my VM16 with centurion 6 control and it shut down and will only go into dos mode. Does anyone know the DOS Commands so that I can get to the parts directory and delete some programs. I did this once before and called into milltronics and they guided me through what I needed to do. But being the weekend I can't do that and I hope to work this weekend.
    Thanks for any help
    Nov 2013
    128
    I think it would be something like this:
    CD.. then enter, then "DIR" then enter, you should be able to see the parts folder in the C: directory, then "CD PARTS" , you should now be in the parts folder, pick the file that you want to delete and type "DEL FILENAME" and enter, after deleting as many as you need type, "CD.." then enter, then "AUTOEXEC.BAT" and enter and the cnc should boot up.
    Nov 2008
    47
    Quote Originally Posted by allenmullis View Post
    Other than being on the B: drive that worked.
  1. Centurion 7 help
    By absolut in forum Mastercam
    Last Post: 05-17-2010, 05:21 PM
  2. Centurion IV
    By cncdiag in forum Milltronics
    Last Post: 01-14-2010, 03:37 PM
  3. Centurion 5 vs. Centurion 6 and validation codes
    By Turbo VW in forum Milltronics
    Last Post: 02-11-2007, 09:35 PM
  4. I'm Considering a Centurion 1
    By TZ250 in forum Milltronics
    Last Post: 09-07-2006, 08:30 PM
  5. Centurion 7
    By Enda in forum Milltronics
    Last Post: 01-26-2006, 01:00 AM
