586,096 active members*
3,704 visitors online*
IndustryArena Forum > MetalWorking Machines > Colchester Tornado lathes > Colchester 3000L Bar puller problem, program stops after M78/M79
    Jan 2014
    5
    Hi All,
    Long time lurker, first time poster here.
    We recently acquired a Colchester 3000L CNC Lathe with Fanuc OT control.
    Amazingly, everything is working just fine with the exception of bar puller work. The programme just stops after either an M78 or M79 when in auto run mode, my program is as follows (we are using a 'crocodile' style puller):
    T0404
    G00X20Z-14.6
    G94G01X-10F500
    M78
    #HAVE TO PRESS CYCLE START HERE#
    G04U2.0
    G01W10
    M79
    G04U2.0
    G01X20
    G00X200Z200
    I have tried M31/M32 to 'ignore' the spindle interlock function but the program just freezes when it tries to run the codes (I assume it doesn't recognize them).
    Can anyone point me in the right direction?
    The book clearly states that M78/M79 are for opening and closing the chuck for bar feed/bar pull work.
    Any help much appreciated, also I am missing the Fanuc OT Operators Manual if anybody has a spare copy!
    Thanks all, John
    Jun 2004
    511
    Google Fanuc OT.pdf
    Feb 2009
    6028
    Does it actually open the chuck then stop? I'd guess you have proximity switches on the actuator you need to adjust, or some machines use a hydraulic pressure switch.
    Sent from my G-Tab Quantum using Tapatalk
    Jan 2014
    5
    Thanks all for the replies, we have diagnosed the 'chuck closed' sensor is dead, so we are working on replacing that, will feedback soon if that solves the issue.
    Currently have a guy pushing the button each time!
    Jan 2014
    5
    Re: Colchester 3000L Bar puller problem, program stops after M78/M79
    For anyone who experienced this problem, it was a pressure check within the chuck open/close cycle that caused the issue. Once we wound on the pressure a bit this functioned perfectly!
  1. PARAMETERS FOR COLCHESTER 3000L WITH FANUC OTA
    By raymond.baker8@ in forum Fanuc
    Last Post: 09-01-2023, 02:16 PM
  2. Duplomatic Turret Issues - Colchester 3000L
    By ricka in forum Colchester Tornado lathes
    Last Post: 03-10-2016, 08:01 PM
  3. Bar puller problem
    By autotrol9 in forum G-Code Programing
    Last Post: 04-29-2013, 12:51 PM
  4. Haas Bar Puller Problem
    By fboling in forum Haas Lathes
    Last Post: 12-22-2010, 04:51 PM
  5. Bar Puller Program Problem
    By fboling in forum CNC Machining Centers
    Last Post: 09-16-2010, 08:08 PM
