586,113 active members*
3,291 visitors online*
Results 1 to 10 of 10
    40
    co2 tube problems
    Hi All
    I hope you can help
    I bought an 80 watt CO2 laser tube and I am having problems and hope you can help.
    The tube is brand new but has been boxed waiting for install for 12 months
    I loose power after about 20 minutes with the pump running even if I don’t fire the laser
    When I press the Test button on the power supply I get 14 mA current and I can see a pink glow in the tube , no arcing of the voltage
    The laser has power then after about 5 minutes of running the power almost disappears and almost no mark on thermal paper at the end of the tube
    My set up is as follows
    Tube is 80 watts and 80 watt power supply
    I have a water chiller and the temp is set to 16 deg C
    Anode and cathode connections OK
    Water flow correct and is dematerialized water
    The pump is a water fountain pump
    I have a water flow meter connected and the flow is 7 to 10 L per hour
    Any suggestions.
    Regards peter
    Nov 2010
    787
    12 months is the answer.
    CNC lasers, constructions, service
    14Ma is way too low to sustain an arc, 22 to 26 is closer to what you need. it may be down to age as Cine said but it could also be too low a current from the power supply.
    cheers
    Dave
    40
    Hi Dave thanks , even at 22ma it still has the same problem , if I turn off the water pump and leave for about an hour it works ok for a while then after about 5 mins power drops off , cant see how a tube in storage could be the problem..
    peter
    Nov 2012
    492
    I have never had that problem but I have read many times were tubes loose gas just sitting around and not being used. Thats the reason Tube warranties start the day of manufacture and not the installation date, or at least thats what I read. So it could be the tube or as Dave said low output from PS.
    Nov 2010
    787
    Quote Originally Posted by peterklos View Post
    Just you see.
    Hi Peter,
    Tubes can liberate gas through the glass walls given enough time (and through the joints) the electrodes also corrode due to impurities in the gas mix leading to low power being applied to the mix.Remember the tube you stored for a year may well have been a year old by the time you received it from it's date of filling.
    cheers
    Dave
    Nov 2010
    787
    Quote Originally Posted by Exsecratio View Post
    Hi Peter,
    This is urban legend. How will you explain that the same laser will work 2 or more years if is not stored but working? :-)
    Working laser do not "liberate gas through the glass walls"?
    try again
    CO2 tube problems
    peter
    The laser tube lost the power, you need to buy a new laser tube.
    Where are you? In Canada?
  1. Tap holes in the end of aluminum tube, Tube will be provided
    By WRichards in forum North America RFQ's
    Last Post: 10-17-2012, 12:30 AM
  2. I changed from synrad rf laser tube to glass tube and it is not working good
    By david Neumann in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-15-2012, 03:22 AM
  3. Difference between Chinese Glass tube and RF Tube...
    By InfernusDoleo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-08-2012, 03:44 AM
  4. tube endforming equipment for telescoping tube
    By DanP in forum Want To Buy...Need help!
    Last Post: 01-23-2012, 11:32 AM
  5. Tube cutting; tin slots and tube ends
    By marineboy in forum Waterjet General Topics
    Last Post: 10-13-2009, 10:03 PM
