586,104 active members*
3,449 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Star sr32j program example with 18i fanuc control
    Feb 2014
    Does anyone have a proven program sample. I am using partmaker cad/cam and the post is no where near right. I don't have a working example program either.
    Sep 2011
    17
    I use Partmaker and the posts I have for our Stars very good.
    Here is a good working program for thee SR32j. Main side first Hope this helps it should.
    O4009
    (PROGRAMMED BY STAR_SR_32J PROCESSOR VERSION V38.0)
    M09 (CANCEL C AXIS)
    M26 (COOLANT OFF)
    G0 G40 G80 G97 G99 M5
    #528=0.08 (CUTOFF WIDTH)
    #529=600 (CUT OFF RPM)
    #530=0.71 (PART LENGTH)
    #531=0.75 (STOCK OD)
    #2601=-10.91
    (SAFETY FOR CUTOFF TOOL NOT BEING IN FRONT OF STOCK)
    IF[#5041 GT0] GOTO1000
    M11
    G0 Z0. T0
    M10
    G120 Z0.
    M200
    M26
    M20
    M1
    N1 (FACE)
    T200 (CCGT32.51 .015R )
    G97 S483 M3
    G18 G99 G0 X0.76 Z0. T02
    /M25
    G1 X0.72 Z0. F0.001
    X-0.03
    X-0.07
    G0 G97 X5.6 T0
    M1
    M205
    N2 (.312 DRILL)
    G191 Z.1 (FRONT TOOL INTERFERENCE CHECK)
    T1200 (SPOT DRILL_0.375 )
    G97 S1000 M3
    G18 G99 G0 X0. Z-0.05 T12
    G1 Z0.15 F0.0015
    G0 Z-0.05
    G0 G97 X5.6 T0
    M1
    M210
    N3 (.312 DRILL)
    T1300 (DRILL_0.312 )
    G97 S620 M3
    G18 G99 G0 X0. Z-0.05 T13
    G1 Z0.75 F0.0015
    G0 Z-0.05
    G0 G97 X5.6 T0
    G190 (FRONT TOOL INTERFERENCE CHECK CANCEL)
    M1
    M215
    N4 (BORE .380)
    T1100 (.004R MAIN BORE )
    G97 S867 M3
    G18 G99 G0 X0.456 Z0. T11
    G50 S1000
    G96 S100 M3
    G1 X0.416 Z0. F0.0008
    X0.4
    G3 X0.3887 Z0.0023 R0.008
    G1 X0.3847 Z0.0043
    G3 X0.38 Z0.01 R0.008
    G1 Z0.02
    X0.3314
    X0.3097 Z0.0308
    X0.2814 Z0.045
    G0 G97 X5.6 T0
    M1
    M220
    N5 (RGH O.D. FIN .687)
    G97 S561 M3
    G18 G99 G0 X0.65 Z-0.005 T02
    G50 S1000
    G96 S100 M3
    G1 Z0.015 F0.001
    Z0.41
    X0.7
    Z0.03
    X0.55
    Z0.4103
    G3 X0.573 Z0.415 R0.0165
    G1 X0.7
    Z0.03
    X0.47
    Z0.261
    X0.5212 Z0.3054
    G2 X0.54 Z0.3404 R0.07
    G1 Z0.3985
    G1 X0.7
    Z0.03
    X0.42
    Z0.2177
    X0.5212 Z0.3054
    G1 Z0.3886
    X0.687 Z0.4201
    Z0.705
    X0.7211
    X0.7572 Z0.7437
    X0.7741 Z0.7618
    G0 G97 X5.6 T0
    M1
    M225
    N6 (FINISH O.D.)
    T400 (VBMT .015R RIGHTHAND )
    G97 S1330 M3
    G18 G99 G0 X0.314 Z0. T04
    G50 S1200
    G96 S120 M3
    G1 X0.354 Z0. F0.001
    X0.37
    G2 X0.3912 Z0.0044 R0.015
    G1 X0.3952 Z0.0064
    G2 X0.404 Z0.017 R0.015
    G1 Z0.0668
    G3 X0.395 Z0.064 R0.005
    X0.385 Z0.069 R0.005
    G1 Z0.217
    G3 X0.3863 Z0.2195 R0.005
    G1 X0.4912 Z0.3104
    G2 X0.51 Z0.3454 R0.07
    G1 Z0.4035
    G3 X0.543 Z0.42 R0.0165
    G1 X0.6594
    X0.687 Z0.4338
    Z0.72
    Z0.74
    G0 G97 X5.6 T0
    M1
    M230
    N7 (CUTOFF)
    T100 (CUT-OFF .08 )
    G99 G0 Z0.79 T0
    M3 S500
    M82 (SYNC - WAIT)
    M235
    M40 (Z1-Z2 FOLLOWING ON)
    G97 S600 M3
    G18 G99 G0 X0.788 Z0.79 T01
    G1 X0.748 F0.001
    X-0.002
    X-0.042
    /M26 (STANDARD COOLANT OFF)
    M41 (Z1-Z2 FOLLOW OFF)
    M83 (SYNC ROT OFF - WAIT)
    G97 M3 S500
    M1
    M80
    M81
    M5
    M99
    N1000 (AUTO CUT-OFF)
    M10 (MAIN COLLET CLAMP)
    M25 (COOLANT ON)
    G28 U0
    T100
    G0 X[#531+.100] M3 S#529
    G99 G1 X-0.042 F0.001
    G97 M5
    M26
    M99
    O4010
    M09 (CANCEL C AXIS)
    M26 (COOLANT OFF)
    G28 W0 T0
    G50 Z0
    T2000
    G130
    M200
    M26
    M20
    M75 (BLOCK SKIP VALID)
    M1
    N8 (FACE)
    /T2100 (CCGT32.50.5 .008 RAD. )
    /G18 G97 S400 M3
    /G0 X-0.774 Z0. T1
    /G1 X-0.734 F0.001
    /X0.016
    /X0.056
    /G97
    /G28 W0 T0
    M1
    M205
    M210
    N9 (DRILL)
    /T2200 (DRILL_0.39 )
    /G18 G97 S490 M3
    /G0 X0. Z-0.05 T22
    /G1 Z0.5 F0.0012
    /G0 Z-0.05
    /G97
    /G28 W0 T0
    M1
    M215
    N10 (RGH BORE)
    /T2300 (SCIENTIFIC BORE (SUB) )
    /G18 G97 S940 M3
    /G0 X0.41 Z-0.018 T3
    /G50 S1000
    /G96 S100 M3
    /G1 Z0.002 F0.0008
    /Z0.4014
    /X0.3343 Z0.467
    /G3 X0.3195 Z0.4903 R0.057
    /G1 X0.3191 Z0.5035
    /X0.308
    /Z0.004
    /X0.43
    /Z0.3841
    /X0.3917 Z0.4173
    /X0.378
    /Z0.004
    /X0.4889
    /Z0.0253
    /X0.438 Z0.0591
    /Z0.0037
    /X0.5348 Z-0.0051
    /X0.432 Z0.0631
    /X0.408
    /Z0.002
    /Z-0.018
    /G97
    /G28 W0 T0
    M1
    M220
    N11 (FINISH BORE)
    /G0 X0.565 Z-0.0152 T3
    /G1 X0.541 Z0.0008 F0.0007
    /X0.444 Z0.0651
    /Z0.3772
    /G2 X0.4392 Z0.3862 R0.018
    /G1 X0.3343 Z0.477
    /G3 X0.319 Z0.5055 R0.057
    /G1 Z0.807
    /Z0.827
    /G97
    /G28 W0 T0
    M1
    /T2900 (EJECT)
    /M5
    /G0 Z0. (RELEASE Z)
    /M11
    /G4 U1.0
    /G0 Z0 T0
    M1
    M76 (BLOCK SKIP INVALID)
    M225
    M230
    T2000
    M4 S500
    M82 (SYNC - WAIT)
    M11 (OPEN SUB)
    G131
    G0 Z-0.6
    M68 (TORQUE LIMITTER ON)
    G98 G1 Z0.05 F50.0
    M69 (TORQUE LIMITTER OFF)
    G99
    M10 (CLOSE SUB)
    G130
    M235
    G0 W-.1
    G28 W0 T0
    M5
    M99
    Sep 2022
    Re: Star sr32j program example with 18i fanuc control
    Does anyone know if it is possible to control the sub-spindle from a program on Head 1? I run a warmup program in the morning that ramps up the spindle RPM, and I didn’t want to have 2 separate programs to warm up each side. It’s not a big deal but I always try to make my life easier.
    Sr-32J Fanuc 18i-TB
  1. star SR32J please HELP!!!!
    By chipsmagee in forum Community Club House
    Last Post: 08-25-2012, 11:32 AM
  2. Cutter comp on Y,Z axis, Star Swiss 20 with fanuc control.
    By Travisr145 in forum CNC Swiss Screw Machines
    Last Post: 08-12-2012, 05:14 AM
  3. Program # increase on fanuc 16-M control
    By beam in forum RFQ Feedback
    Last Post: 11-20-2008, 07:53 PM
  4. Resequencing program in fanuc 18i control
    By ios1000 in forum Fanuc
    Last Post: 08-18-2008, 02:51 PM
  5. Fanuc O-M Control not receiving program
    By trutec423 in forum Uncategorised MetalWorking Machines
    Last Post: 08-04-2007, 01:25 PM
