586,108 active members*
3,097 visitors online*
    Feb 2014
    4
    Exclamation Duoble beam PROBLEM !
    Hello,
    I got problem with laser beam.
    From top about 150 mm of Y axis I got 2 beams, one original which cutting, second wider and going near originals "line".
    Mirror alignment correct.
    Where's problem? With focus lens?
    Any help are welcome !
    Attachment 221690
    Scatter, the beam is hitting the inside of the aircone. You need to adjust the alignment of the mirrors from the first one to the last.
    cheers
    Dave
    double beam problem
    Quote Originally Posted by buhajus View Post
    Hello,
    Attachment 221690
    If mirror alignment is correct, maybe focus lens problem. In additon, maybe the tube of laser head is not vertical.
    Good Luck.
  1. k40 type chinese laser problem with beam/power please Help
    By justy22 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-01-2013, 09:05 PM
  2. How align IR beam (co2) with visible beam (red dot laser) ?
    By etienne delcuve in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2009, 12:41 PM
  3. beam
    By lgalla in forum Mechanical Calculations/Engineering Design
    Last Post: 03-27-2008, 04:58 AM
  4. Beam quality problem ...
    By smartcut in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-26-2007, 09:17 PM
  5. Short beam/Long beam? - Basic design
    By Pat2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2005, 05:49 AM
