586,075 active members*
4,127 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    Oct 2013
    19
    First cnc router build
    Hey guys. I'm so glad that I found out for this community!
    First let me start introducing myself. My name is Darko and I come from Serbia.
    I am young mechanical engineer, working as Instrumentation Engineer in Oil company.
    Few years back, I have worked with some CNC mill and lathe, so I am familiar with writing G code and stuff.
    I have an idea to make cnc for myself, and I choose JGRO design for it.
    First, I have made 3D assembly in Catia, with all necessary parts, and now I am working on technical documentation.
    Material will be MDF. Lead screw is 16mm diameter with anti backlash nut (pictures tommorow for this).
    I will use step motors, probably Nema23. Not sure about electronics yet, maybe I will buy some kit, or something like that.
    I will post some pictures of my model, and I would like to hear from you what do you think.
    Nov 2007
    483
    If you plan on modifying the x-axis to use manufactured rails I would highly recommend going with supported rail. Acutally I would recommend using supported rail on both the x and y and go with a different design if you can afford it.
    Oct 2013
    19
    I dont have unlimited budget, because I want this to be as low as possible, but functional.
    I can find cheap supported rails, and I have been considering this, so main question is, do you think that this is necessary because unsupported rail will bend?
    When I come home, I will try to do FEM analysis on this part with some maximum load, to see what will happen.
    Also, I'm not sure yet if I will use gas pipe or some SS bar.
    Oct 2013
    19
    This is gas pipe, stainless steel. Under 50kg load on one side of the gantry max displacement is 0,017mm. I beileve that this is very good.
    I would appreciate comments from some experienced cnc builders.
    Nov 2007
    483
    You have to take into consideration that deflection will happen on both rails at the same time then you have to factor in the length of the lever to where you cutter is. Gas pipe is ok at slower cutting speeds but you will have deflection. I started with a JGRO and it was great for a machine built with no access to cnc. It let me build a better machine which I use today.
    Have fun with your build.
    Oct 2013
    19
    I'm back. I've been busy a little. I am very glad that this idea didn't stop here and I hope I will see end for this project.
    I bought these linear berings, four big 20mm diameter, and eight of them smaller, 16mm diameter.
    Adjustment blocks:
    X axis ballscrew:
    Steel rods:
    And of course MDF
    I don't have all parts for machine, but I'm getting there...
    These days I will start putting together all parts and I will post pictures here to show my progress.
    Oct 2013
    19
    It's been very fun putting all pieces together. I had some problems with linear motion bearings, but I managed to align them.
    There are still some things to do. I need to buy two ball screws and electronics kit with step motors.
    Top torsion box is not mounted yet, I hope today when I come home, that will be done.
    I hope someone will join this monolog of mine, so we can have a discussion.
    Oct 2007
    10
    Re: First cnc router build
    Are you still working on it?
    Oct 2013
    19
    Yes, I finished it. I am just waiting for spindle, it should arrive very soon.
    I did not post any updates because I see that no one is interested.
    Feb 2014
    I just stumbled upon this build. Looks great! Would love to see it all together and running!
    Personally, I'm interested in the electronics as well as what you're going to be using to generate g-code.
    Oct 2013
    19
    Thank you. I will take picture of router when I come home from work. I have in my phone some pictures of electronics, so take a look. First picture is some box that I made for drivers and power supply. On second picture, you can see three drivers, breakout board, and on the left two power supllies for drivers. On the right you can see atx power supply for breakout board.
    Attachment 240188Attachment 240190
    Oct 2007
    10
    It does look like the interest in the diy machines have died off. I guess everyone has so much money now they are just buying commercial machines. I do not fit into that group so will stick with the build it yourself stuff
    Nov 2007
    483
    It's not that DIY has died off. If anything it's bigger than before. The difference now is what parts and kits are avalaible, as in many. Back when JGRO was first designed there was not a lot out there for the DIYer. It was a great plan that allowed anyone to build a cnc with common tool. We've come very far as a community since then and there are better value options for your money now.
    Oct 2013
    19
    Here are some pictures of almost finished cnc router. Sorry for dust, dirt and other stuff that I "forgot" to clean.
    Yesterday I have installed spindle (chinesse 1.5kW with inverter) and I encountered a problem.
    When Z axis with spindle is going down, I can hear very loud scratching noise. On the other hand, when it is going up, everything seems to be fine.
    I think that there is some big time friction between nut and leadscrew due to almost 5kg spindle weight. Only Z axis have regular lead screw, other two axis have ballscrew.
    Here is a short video so you can have better picture what is going on...
    I hope that someone can give me advice on how to fix this issue.
    Oct 2013
    19
    Problem solved!
    I would like to share my success with you guys. I present you my first work on CNC router build from scratch:
    Jul 2014
    19
    Hello Dear Daredzoni,
    I am having the problem you gave us on youtube ,, could you please tell me why the sound is there ?? is it really scratching from the nut and screw??
    Please i need your help in this.
    Best Regards
    Oct 2007
    10
    Quote Originally Posted by jckstrthmghty View Post
    What would you suggest? All the machines I am seeing are in the thousands and I just don't have that to spend on another hobby
    Oct 2013
    19
    Quote Originally Posted by NobelO View Post
    Best Regards
    Sorry for taking me ages to answer. It was axis misalignment problem. I sort this out by tightening adjustment blocks on Z axis. I hope that you have resolved your problem.
    I would like to share some of my recent works on this machine:
    This font is cyrilic. It is my little nephew's name.
    My city is called Pančevo, so out of boredom I made this:
    Oct 2013
    19
    In Serbia two biggest football clubs are Red Star ( Црвена Звезда ) and Partizan.
    I am not satisfied with paint job. It took me hours to paint it, and when I applied clearcoat, this linden piece went yellow.
    Oct 2013
    19
Page 1 of 2 12
  1. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  2. New Router Build
    By nulluser in forum DIY CNC Router Table Machines
    Last Post: 03-29-2011, 11:14 PM
  3. Building a CNC Router; by someone who can't build a CNC Router
    By Womble in forum DIY CNC Router Table Machines
    Last Post: 09-27-2008, 01:51 PM
  4. Router Using 3/4" MDF (first router build)
    By eguy208 in forum CNC Wood Router Project Log
    Last Post: 04-11-2008, 04:33 PM
