586,036 active members*
3,578 visitors online*
Page 3 of 3 123
Results 41 to 53 of 53
  1. #41
    Mar 2015
    Sorry to bring up an old thread, but I have been trying to look at these pictures posted and they don't show up.
    I have a 110-2031 enco that is probably the same as the ones in this thread. I am looking for wiring diagrams because the drum switch broke, trying to find a correct replacement.
    A switch company I have talked to can make one but we need a diagram to go by.
  2. #42
    Oct 2013
    12
    Re: Wiring issues...enco lathe
    Hi and welcome St1977,
    I have the Central Machinery TD-1236B shown in one of the pics and farshot83 owns the ENCO 110-2032. He shot me some pics of the drum switch so I could figure out the wiring positions on the drum switch. From there I put some pics up showing the wires positions and colors. If they are not coming thru for you, PM me and I can forward them to you in an email. Just a note, I am not sure if your 110-2031 has the same drum switch as both of ours. There are pics of both his and my drum switches posted so you can determine if yours is the same.
    All the best on getting your lathe running and making some chips.
  3. #43
    Dec 2020
    6
    Hi
    Im looking for a manual for the TD-1236B, can you help me with that
    Ed
  4. #44
    Oct 2013
    12
    Quote Originally Posted by edkel1 View Post
    Hi
    Ed
    Hi Ed, you will find a pdf of my TD-1236B owners manual in #'s 36-37 for download. This is the only info I have accept those that are posted by others here. I hope this helps you!
    Paul
  5. #45
    Dec 2020
    6
    Thanks I downloaded that, I have several other questions , can we talk ?????
    PLMK
    Ed
  6. #46
    Quote Originally Posted by farshot83 View Post
    Its fixed. I cleaned up the contacts in both contactors and now I get the appropriate voltage. All is working as it should.
    Thanks again for all the help.
    I'll help on here when I can.
    It is great to hear that.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  7. #47
    Oct 2013
    12
    Hi edkel1, I am not sure if I have any answers beyond the manual, but what are your questions?
  8. #48
    Dec 2020
    6
    what kind of oil, its low and dont know what type, where to you get replacement 1/4 turn door handles for the base
    I will have more questions as I clean it up
    Ed
  9. #49
    Oct 2013
    12
    Ed
    Hi Ed, The manual says to replenish with 30wt. lubricant. I am not sure that the 1/4 turn handles are aivailable any more. A good little project and seems very easy project. I might be able to shooy a couple pics of the factory handles to give you an idea. All the best, post a few pics as you go along so we can enjoy your progress.
    Paul
  10. #50
    Dec 2020
    6
    I have one good handle but have been looking and cant find anything to match it and as far as oil I must have missed it in the manual, thats on me
    Thanks for answering
    Ed
  11. #51
    Oct 2013
    12
    Ed
    Awesome, keep up the good work.
  12. #52
    Dec 2020
    6
    Paul, is there any other oil I can use instead of DTE Light as in ATF, 5-20w motor oil or should I just stick with the DTE Light and how much will it need mine was real low , got about 32 ozs out of it, I was thinking 2 qts ?????, have lots of questions coming
    Ed
  13. #53
    Oct 2013
    12
    Ed
    Hi Ed, Look on page 16 & 17 of the manual I gave to doewnload. These talk about the oil and quantity.
Page 3 of 3 123
  1. Switch for Enco lathe
    By ed0307 in forum Uncategorised MetalWorking Machines
    Last Post: 05-17-2009, 12:08 AM
  2. ENCO 13 x 40 lathe and VFD
    By Supercel in forum Phase Converters
    Last Post: 08-11-2008, 02:41 PM
  3. Enco 14 x 14 lathe?
    By dannirr in forum Uncategorised MetalWorking Machines
    Last Post: 04-21-2008, 03:02 PM
  4. Enco 9 x 20 Lathe Restoration
    By warossignol in forum Mini Lathe
    Last Post: 04-03-2008, 08:40 PM
  5. Enco Lathe
    By ccm in forum Mini Lathe
    Last Post: 10-21-2003, 10:34 PM
