Just some food for thought. Before you spec out the rack, you should look at the stepper's [ or servo's] your using and figure out the max torque they are going to put out, then multiply it by 3 [ your reduction ratio] this will give you a number to check your rated strength of the pinion gear. I'm finishing up a large format milling machine and ended up using 12DP as anything less than that was just going to bust the gear. 20DP sounds great until you look at it.. its TINY! I know that plasma's typically don't run into the same cutting forces as a mill or router, however.. Acceleration is your worst enemy, and rumor has it that some plasma's really move.. upwards of 1000IPM so.. make sure the pinion you pick is strong enough for your application.
Bostongear.com has some great info you can look up and check to see if your pinion will stand up to the torque load.
My 2 cents..
Jerry
JerryFlyGuy
The more I know... the more I realize I don't
