586,036 active members*
3,493 visitors online*
Results 1 to 6 of 6
    Jan 2014
    4
    Unhappy 3040T-DJ 3 axis cnc, need LinuxCNC help
    im really having a hard time with the stepper mill config
    has anyone setup one of these machines ??
    can you point me in the right direction
    as far as the axis config, steps per... microsteping...lead screw pitch ... ect i just cant get it to
    cut accurately can some one post there numbers,
    the one i have is the yoocnc T-DJ 3 axis black control box here is a link to what it looks like
    Latest Mini CNC 3040t DJ Desktop CNC Router for Drilling & Milling Updated from CNC 3040 [CNC 3040t DJ] - $712.90 :
    the only thing i got with it was mach 3 settings but i am unable to figure out how to apply them to the Linuxcnc
    any help would be greatly appreciated
    Jan 2012
    hmm a little quite here. B-)
    Did you do a test cut of a known size square? what was the resulting size compared to the gcode? larger or smaller on each axis? Both the same offset or different?
    Here is some stuff I have dug up so far. But you are correct, we need to measure the lead screw pitch.
    the steps look to be a choice of 200 400 or 320 per revolution.
    1.8 deg. per step = 200 steps/rev this seems to be most common.
    .9 deg per step = 400 steps/rev
    1.125 deg per step = 320 steps per/rev
    once we know the lead screw pitch and we know the steps per rotation then we can calculate travel and calibrate your setup. Some testing will get us to the correct values.
    Here are the settings one guy used. I would not worry about the micro step yet. You need to measure your lead screw pitch. As you can see it is not the same value on all axis of this guys machine, maybe the same as yours. And if you are who I think you are then they are all currently set the same on your machine.
    Using the stepconf
    Units: Millimeter
    Driver type: other
    Step time: 5000
    Step space : 5000
    Direction hold :2000
    Direction setup : 2000
    First parport Base Add: 0x378
    Base period Maximum Jitter: 35000
    Parallel port setup
    Pin1 - Spindle PWM, Pin2 - Not used, Pin3 - Not used, Pin4 - Ystep (inverted), pin5 - Ydirection, Pin6 - Zstep (inverted), Pin7 - Zdirection (inverted), Pin8 - Not used, Pin9 - Not used, Pin10 - Estop in, Pin11 - Not used, Pin12 - Not used, Pin13 - Not used, Pin 14 - Spindle CW, Pin15 - Not used, Pin16 - Xstep (inverted), Pin17 - xdirection.
    X-AXIS CONFIG:
    Motor steps per revolution: 200
    Driver microstepping: 8
    Pulley teeth ratio: 1:1
    Leadscrew pitch : 4.0
    Maximum velocity 25 mm/s
    Maximum acceleration: 30 mm/s/s
    Table travel : -3.0 to 290.0
    Y-Axis config:
    Leadscrew pitch : 5.0
    Table travel: -3.0 to 390.0
    Z-Axis config:
    Leadscrew pitch : 2.5
    Maximum velocity: 15 mm/s
    Table travel : -10.0 to 35.0
    Jan 2012
    OK found this spec on this page.
    CNC 3040T-DJ mini cnc Router Engraver Milling/Drilling Machine, Ship from EU/USA warehouse, no extra custom duty and VAT, View cnc 3040T-DJ, CNC Product Details from Shenzhen Liyang Welding Equipment Co., Ltd. on Alibaba.com
    It says the following and I assume it is talking about the lead screw
    Drive unit: 1204 Double thread Trapezoidal Screw
    So the lead screw on your cnc is supposed to have a 12mm diam with a 4mm lead per revolution.
    More pieces to the puzzle. Do we have to many pieces now?
    Jan 2014
    4
    yea the china supplyer said they don't know any details of the cnc ... go figure
    I saw the 1204 but I didn't know what it meant ... im still learning about all the parameters that go into setting up a cnc . but im eager to learn all the in's and outs ., thanks G for all the help
    Jan 2014
    4
    looks like I got it setup !! , I will share my config soon , Thanks Neusse
    Feb 2014
    6
    Re: 3040T-DJ 3 axis cnc, need LinuxCNC help
    Can you share your config please. I believe I have the same machine and am having some accuracy issues too.
    David
  1. Replies: 12
    Last Post: 09-06-2013, 01:02 PM
  2. Replies: 0
    Last Post: 07-01-2013, 04:08 PM
  3. LinuxCNC axis calibration
    By bianchi in forum LinuxCNC (formerly EMC2)
    Last Post: 10-03-2012, 03:03 PM
  4. LinuxCNC axis calibration
    By bianchi in forum Open Source CNC Machine Designs
    Last Post: 06-30-2012, 03:17 PM
  5. X-Axis Stalling with LinuxCNC
    By mrfweet in forum LinuxCNC (formerly EMC2)
    Last Post: 03-18-2012, 10:41 PM
