586,525 active members*
3,377 visitors online*
    Feb 2014
    7
    mach3 won't read in full gcode program all the time
    I have mach3 running a chinese machine (x61500GT) from Carving-cnc. It uses a USB connection. The machine is well built, but as expected, comes with no documentation or software. Upon getting Mach3 and finding the plug in usbmove and a quick start pdf, I was able to get the machine to run correctly. I then made a gcode program and uploaded it into Mach3. I ran it and the program worked for a bit and then stopped. I soon found that the file was only partially loaded. I shut down mach3, restarted, loaded the program and it showed as fully loaded. I ran it, it went farther then before, but stopped. Upon review, only part of the program was in memory......
    I have the fully registered Mach3, so it is not limiting the file size for demo mode. Any ideas?
    Is it registered to you, or did you get a license from the Chinese seller? A lot of Chinese sellers provide pirated licens files, which often don't work correctly.
    Feb 2014
    7
    Yes, it did have to do with registration not being done right. I got the registration correct and the code is now feeding fine. Thanks,
    Sent from my SPH-L900 using Tapatalk
  1. Steps to develop VB program to read CNC (G-code) program.
    By BhushanM01 in forum Visual Basic
    Last Post: 12-12-2017, 07:57 PM
  2. mach3 not loading full gcode
    By shiv15uk63 in forum Mach Software (ArtSoft software)
    Last Post: 04-09-2013, 01:48 PM
  3. Full-Time CNC Machinist
    By simplymachining in forum BobCad-Cam
    Last Post: 08-12-2008, 05:43 AM
  4. Looking for a full-time job in southern MA
    By AtomicBeaker in forum Employment Opportunity
    Last Post: 05-19-2006, 03:43 AM
  5. I can read my GCODE into MACH2 :(
    By Seventeen in forum Mach Software (ArtSoft software)
    Last Post: 09-17-2005, 11:18 PM
