586,052 active members*
4,400 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > what do you use for lubrication on your machine?
Results 1 to 7 of 7
    Oct 2007
    446
    Question what do you use for lubrication on your machine?
    what do you use for lubrication on your machine? on the rails? bearings? ballscrews?
    I have one of the first xzero machines...will Superlube do the trick?
    Jun 2004
    511
    Mobil Vactra 2 is made for machine lubrication, Superlube having teflon cant be bad. Based on what you are cutting the grease my cause particals to stick to the critical parts.
    Oct 2007
    446
    well i was thinking of using the superlube grease on the ballscrew nut since it has a grease fitting..and then just spray superlube for the round rails...there is a "dry" superlube as well..not sure if that would be better??
    Apr 2012
    90
    I use vactra#2 and vactra#4 depending on the machine. Your machines manual should specify what to use.
    24221
    +1 on the Vactra-2.
    One of the most widely used in the industry.
    Al.
    Albert E.
    We use Kluber Isoflex NBU15 on the ballscrews and linear bearings of our Morbidelli router. It's very expensive, though, at about $100 per tube.
    Feb 2006
    19
    Kluber grease is only necessary for the drilling spindles. Any good semi liquid grease (viscosity grade 00) will do for the ballscrews and linear bearings
  1. new machine lubrication concept
    By Brucesu in forum News Announcements
    Last Post: 03-12-2011, 02:33 AM
  2. Lubrication !
    By zaebis in forum Novakon
    Last Post: 02-07-2010, 09:09 PM
  3. Machine tool spindle lubrication experiment
    By NC Cams in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2007, 04:55 PM
  4. Sino-nsh LV Lubrication Oil Recovery machine
    By sinonsh22 in forum News Announcements
    Last Post: 10-26-2006, 07:05 AM
  5. Lubrication
    By BeerFizz in forum Benchtop Machines
    Last Post: 11-10-2005, 01:25 AM
