586,043 active members*
3,631 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > Mach3 PostProcessor generating crazy toolpath. (huge circles)
    Sep 2013
    13
    Question Mach3 PostProcessor generating crazy toolpath. (huge circles)
    I downloaded Mach3 PostProcessor for Mach3. I'm using SW 2013 Pro and Mastercam X4. Files are saved as IGS/Parasolid.
    Problem is that toolpath which looks normal in Mastercam, looks crazy in Mach3
    Attachment 222182
    Attachment 222184
    Code:
    N150 G00 X7.5 Y-8.445 S2000 M03
    N160 Z5.
    N170 G01 Z-.976 F560.
    N180 G03 X7.445 Y-8.5 I0. J-.055
    N190 X7.5 Y-8.555 I.055 J0.
    N200 X7.555 Y-8.5 I0. J.055
    N210 X7.5 Y-8.445 I-.055 J0.
    N220 G01 Z-1.951
    N230 G03 X7.445 Y-8.5 I0. J-.055
    N240 X7.5 Y-8.555 I.055 J0.
    N250 X7.555 Y-8.5 I0. J.055
    N260 X7.5 Y-8.445 I-.055 J0.
    N270 G01 Z-2.927
    N280 G03 X7.445 Y-8.5 I0. J-.055
    N290 X7.5 Y-8.555 I.055 J0.
    I have no idea why, when I create very simple toolpath like facing it will generate normal X/Y/Z (CNC is generic Gecko G540 4th Axis machine).
    I need to cut some parts Today and it doesn't working at all. I recently bought it from eBay and I thought that it will work
    Looks that problem is mostly with Pocketing (then it's creating crazy toolpath).
    Change the IJ mode in Mach3
    Sep 2013
    13
    THANKS IT IS WORKING !!!!!!:cheers::cheers::cheers::cheers::cheers:
    Dec 2008
    3109
    The NC program is doing 0.055" radius arcs
    - with no comp applied, this equals 0.110" circle plus your cutter diameter ( say Ø1/4" ), so 0.11 + 0.25 would end up cutting a Ø0.36 hole in your part
    this seems a good toolpath ( a few assumptions are made ).
    so leads to
    - a machine parameter setting
    - cutter compensation previously applied, but not cancelled ( i.e. G40 )
    Look towards Gerry's solution
  1. crazy toolpath?
    By dwneumann in forum MadCAM
    Last Post: 03-21-2012, 08:36 PM
  2. 3D milling toolpath generating unwanted paths
    By Ariel6789 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-05-2011, 11:48 PM
  3. Linegrinder make huge circles under Mach3.
    By oldraven in forum PCB milling
    Last Post: 09-17-2011, 02:01 PM
  4. Huge circles or arcs.
    By wwwmthboardscom in forum Uncategorised CAM Discussion
    Last Post: 05-17-2011, 07:08 PM
  5. Toolpath Group posting generating several NC Files
    By mattford1 in forum Mastercam
    Last Post: 05-31-2007, 01:26 AM
