586,104 active members*
3,403 visitors online*
Results 1 to 5 of 5
    Jan 2007
    206
    Question Rotate a drawing
    I am new to Alibre and was wondering how to rotate a 2D drawing around a point? Kinda like simulating a lifting link arm in up and down position.
    Thank You
    Farmers Machine
    Jun 2006
    3063
    Are you talking about motion simulation or a paper 2D representation of the design?
    Mike
    Jan 2007
    206
    this would be on paper 2D during the preliminary design phase. If you would draw a rectangle with X and Y zero in the center and then tilt it upward 27 degrees from the bottom left corner.
    Thank You
    Farmers Machine
    Jun 2006
    3063
    So, you just want to show the rectangle tilted upward on the drawing? The easiest way might be to create the part with the same tilt and generate the drawing from a front view of the part. You should probably try asking this question on the Geomagic user forum as well.
    Apr 2007
    663
    Re: Rotate a drawing
    I use Alibre Design 10..so no guarantees
    Select figure, then on Tool Bar: Sketch>Rotate..follow instructions
    If there are horizontal and/or vertical constraints, you will have to remove them.
    Also "Snap to Grid" setting may have to be turned off.
  1. Rotate
    By Gallchobhair in forum BobCad-Cam
    Last Post: 11-01-2013, 06:30 PM
  2. dmu 50 rotate B i C
    By rafglow in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 12-07-2010, 05:49 PM
  3. Replies: 13
    Last Post: 10-02-2009, 04:32 AM
  4. converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 12:56 PM
