Hi all,
I have a few very detailed questions on stepper motor drivers for whoever can answer them.
1 If Im driving steppers with Geckos... I move to a y position, and then machine a long line, by moving the x axis only.... At some point in time the y axis Gecko driver will go into power save mode. Will this cause a slight movement in the y axis? ie s slight step in the line.
2 There is a trim pot to adjust for smoothness.... is this compensating for motor non-linearity?
3 When designing a driver to generate step and direction signals, how smooth does the transitions between step frequencies need to be... For example if my timer has a resolution of 1uS I will be able to change from a pulse period of 1000uS to 999uS (around 1Khz) which is just 0.1% increase in frequency... this sounds smooth to me. but If im going from 10uS to 9uS we have a 10% jump which equates to a full 10Khz jump... is there a sensible rule of thumb, and dose it depend on the level of microstepping (eg x10 in this case)
Any help appreciated
Bernard
