Hello, community. I've decided not to multiply new threads, but lead one topic in this section. Little introduction:
I offer a wide range of metalworking & measuring tools, machine tool accessories, cutting tools, diamond & cbn grinding wheels etc.
Most of the tools I sell were produced in the former USSR & possess top quality. New or used, but immaculate and fully functional.
Some tools of the soviet era are quite unique or rare worldwide, though very functional & distinctive.
I've highlighted them in bold red
with some remarks. I think they might be interesting for international community.
So here is the list:
  1. DIAMOND GRINDING WHEEL AC6 200-40-76mm GRIT 120 (125/100) Diamant-Schleifscheibe
  2. DIAMOND GRINDING WHEEL 1А1 125-32-32mm GRIT 500 (60/40) Diamant-Schleifscheibe
  3. T-Slot cutter (9 pcs Set) HSS
  4. Lathe threading die holder attachment MT3 (Morse Taper 3) doesn't reinvent the wheel, but has interesting design
  5. LATHE TOOL HOLDER + 10 CBN / BLACK DIAMOND Inserts for Hardened Steel / Carbides machining HRC 88-90
  6. Spade Drill MT4 (Morse Taper 4) D=32mm
  7. Spade Drill MT3 (Morse Taper 3) D=24mm
  8. Thread Rolling Die Head - M1 (rod/spoke threading head) - rare worthy tool
  9. Thread Rolling Die Head - M1.4x0.3 (rod/spoke threading head)
  10. Thread Rolling Die Head - M1.6x0.35 (rod/spoke threading head) Gewinderollkopf
  11. Thread Rolling Die Head - M2x0.4 (rod/spoke threading head) Gewinderollkopf
  12. Thread Rolling Die Head - M2.2x0.45 (rod/spoke threading head) Gewinderollkopf
  13. Thread Rolling Die Head - M2.5x0.45 (rod/spoke threading head) Gewinderollkopf
  14. Gear Shaper Cutter Module M2 (3 pcs Set)
  15. Gear Hob Cutter Module M3.25 HSS von UdSSR
  16. Gear Hob Cutter Module M4 (Special) HSS von UdSSR
  17. Gear Hob Cutter Module M8 20° HSS von UdSSR
  18. Center Drill Holder MT4 (Morse Taper 4) +2 center drills I've seen such holders on ebay, but not polished & tempered
  19. INDEXABLE TOOLHOLDER CTGNR 2525 M16 for TNG carbide inserts (Klemmhalter CTGNR)
  20. Reamer MT4 (Morse Taper 4) / Reibahle MK4 HSS (Morsekegel 4)
  21. Reamer MT3 (Morse Taper 3)
  22. Reamer MT2 (Morse Taper 2)
  23. Indexable insert centre drill Ø 40 mm
  24. Indexable insert centre drill Ø 25 mm
  25. Centering Microscope Zentriermikroskop "CO-2" (MK4 / MT4) #4 from USSR it's the 4th one I sell, high quality at decent price
  26. Triangular Straight Edge L 320 mm
  27. Square Straight Edge L 200 mm
  28. Mitutoyo VERNIER HEIGHT GAGE 0-450mm (0.02mm) / 18" (Höhenmesser Höhenreisser)
  29. TESA 75-88mm (0.005mm) Internal Bore Micrometer Dreipunkt Innenmikrometer
  30. Vernier Caliper 160mm (0.05mm) + Jaw Scribe Attachment very useful attachment used widely in former USSR, never met it abroad
Shipping: FREE to Europe, N. & S. America, UK
I will gladly answer your questions!
BTW. You can make requests on certain tools. I have way more stuff unlisted.
