586,077 active members*
3,845 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Reduce current to minimize heating
    Oct 2006
    26
    Is there a downside to reducing motor current to reduce heating? My situation is that I need the holding torque when wood routing of course, but the majority of my table use is for the plasma cutter. I know that the motor heat is normal, but would expect longer life if there run cooler in the long run. As plasma cutting is 95% of my table use, I'm considering reducing the current settings on the step controllers (dip switches) for most of the time, using just enough amps to move tool head around. Is there a down side to this idea?
    1695
    There's no downside, as long as it doesn't stall.
  1. heating yay or nay
    By machinecrasher in forum MetalWork Discussion
    Last Post: 10-28-2011, 06:58 AM
  2. Heating Through Glass...
    By ZOMGVTEK in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-19-2011, 04:39 PM
  3. Heating up
    By baham&sons in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-02-2010, 12:12 AM
  4. Replies: 3
    Last Post: 01-06-2010, 11:32 PM
  5. Help with over heating
    By gary-cook in forum CNC Machine Related Electronics
    Last Post: 05-15-2005, 08:35 PM
