586,067 active members*
5,325 visitors online*
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Mar 2018
    Re: johnohara's Techno-Isel DaVinci
    Any suggestions, on controllercard to replace with. Allso it i should buy any other accessories ie. Stepper driver etc. Im using a NSK High speed spindle, wich should be more than enough
    BR. Muffer
    Quote Originally Posted by johnohara View Post
    Pplug~
    I have the serial cable supplied with the machine. Matched the baud rate with the dip switches, etc.
    Plan B.
    ~john
  2. #22
    Re: Removing the Y-Axis
    Hi good day, what kind or name of oil and grease ur use for, and u are using gcode progam ?
    A lot more work involved here. As I suspected, the x and y axis assemblies are identical
    with the exception of how the y-axis attaches to the gantry columns. To clean this
    I decided to disassemble the whole thing. Why not, I was already there.
    Attachment 225128
    Attachment 225130
    Attachment 225132
    Attachment 225134
    Attachment 225136
    Pulled the bolts, removed the column and cleaned it.
    Attachment 225138
    Attachment 225140
    Had to remove the motor to get at all the bolts.
    The connector is for the limit switch.
    The green board terminates the connections to the motor.
    Attachment 225142
    Attachment 225144
    Attachment 225146
    Removed the covers. I doubt it's ever been cleaned.
    Attachment 225148
    Attachment 225150
    Removed the assembly from the gantry column.
    Attachment 225152
    Cleaned up nice.
    Attachment 225154
    Greased the ballscrew and oiled the guides.
    Attachment 225156
    Ready to be re-assembled.
    ~john
  3. #23
    Jan 2011
    7
    Quote Originally Posted by Pplug View Post
    The best thing you can do to that machine is to convert it to run Mach 3 with g540 motor controller. I ran a stock techno for years with the standard g code interface. It was horrible. I then stepped up to running it with the standard electronics and a controller called Gallad with the Kay interface. Finally I bit the bullet and converted it to run mach3. I now get full use of the machine with incredible speed, power and features like spindle speed control and a Z touch off plate.
    In retrospect, I should have done it years ago!
    How did your modification go connecting the g540 controller? How did you connect it and did you change out the power supply? Thank you.
    Rick McCaskill
    [email protected]
  4. #24
    Quote Originally Posted by RickMc View Post
    Rick McCaskill
    [email protected]
    Unfortunately my brother passed away in 2016. His machines sat untouched until last weekend when I took possession of them.
    I had to completely disassemble the machine down to individual pieces to get it out of it’s home unfortunately. Once I get them together and running again I’d be glad to share any information I can about them.
    When disassembling the 4896 I did not see a gecko unit in it anymore. I either missed it or he converted it back to original.
    He also may have been talking about one of the mills he had in his classroom. I unfortunately don’t have any access to it at all.
    Good luck with your machine!
Page 2 of 2 12
  1. Techno-Isel Davinci upgrade help
    By Ferny in forum Controller & Computer Solutions
    Last Post: 08-05-2020, 12:25 PM
  2. Techno / Isel / Tecno Isel confusion
    By H.I.P. in forum Techno CNC
    Last Post: 03-24-2014, 04:02 PM
  3. ISEL Techno G-Code DaVinci Education Mill
    By iflymyhelishigh in forum Commercial CNC Wood Routers
    Last Post: 09-26-2013, 11:16 PM
  4. Techno Isel
    By cuemaker1 in forum Commercial CNC Wood Routers
    Last Post: 12-15-2007, 01:51 AM
  5. Techno Isel
    By wood_donkey in forum Commercial CNC Wood Routers
    Last Post: 04-20-2007, 12:13 AM
