Originally Posted by
brgrii
1. wah-la it works (mostly). Everything seems to be fine except the x axis indicates an overtravel in +x just past what should be the mid point of travel. In the minus direction it will travel all the way to the limit switch.
wah-la (voilá)
Most Fanucs have a button sequence on power up to get rid of software overtravels, I am not sure if this is valid for the 3M but here it is:
Power off the control and before you power it on again the push and
hold at the same time the letter "P" and the "cancel"button then power up
the control, hold down the two buttons until the control powers up
completly. Perform home routine.
Al.
Albert E.
