I followed Mike Henry's instructions on tramming the mill. Related to him by Tormach themselves. (shims under the pads)
Tramming the X was a piece of cake. A 25 thou shim under the right front did the trick. Took it from 6 thou to about 1 thou over 13".
However, the Y refused to improve. It started at about 2 thou over the depth of the table using an indicol and bestest. No matter what I did it barely moved.
I started with all four holddown nuts completely loose and lifted the back, no luck.
Tried again by snugging up the fronts first and lifting the back of the machine (the back was low). Also no luck.
I stuck a 31 thou shim under each back pad - remeasured, hardly moved the reading.
By the way, I know this isn't actually tramming the head but removing twist BUT I should be able to meet factory specs this way apparently.
I can tram my Sharp knee mill dead nuts on in ten minutes no sweat, so I am capable if I know the procedure!
Any ideas?
