586,051 active members*
3,839 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > What size THK/Hiwin rails and blocks?
Results 1 to 12 of 12
    May 2005
    674
    I noticed that the smallest blocks from Hiwin, the 15mm, have a dynamic load capacity of around 2300 lbs each (11K+ Newtons). Static load capacity is double that. Is this correct?
    That's about equal to a 1-1/4" Thomson SMART bearing, and higher than that of a 1-1/2" Thomson SUPER bearing. Pretty incredible from such a small block.
    So why do people even bother with 25mm+ blocks on lightweight routers? I'm thinking it's because of ebay.
    Nov 2005
    264
    you buy what you can find. ive got THK HSR12RM rails, simply becuase it was a killer deal at $60 each for 3 rails that are 26" long and come with 4 trucks each.
    FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
    746
    I managed to get two RSR 9 trucks and a 10.75" rail on Ebay for $36. This will be used on my small router for the Y axis. The smaller truck/rail combos are not that common. I'd love to get another one like it if I could.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Aug 2004
    2849
    Yep....that's the reason....what's available.....though....those 9mm rails.....well they still seem like 'toys'.......
    746
    Quote Originally Posted by ViperTX
    They may be small but there is a set of them on the Y-axis already, I'm going to redo the Y-axis and make it longer. Heck the Z-axis has a 7 mm one. http://www.cnczone.com/forums/attach...chmentid=18614
    This machine is going to be for the small, small stuff. The spindle motor is going to be a Bien-Air brushless motor and controller, just a leftover dental electric handpiece
    35538
    I think a lot of people also don't believe that they'll carry the rated loads, so go with the "bigger is better" approach. Also, the smaller ones don't come in longer lengths, so bigger may become necessary just to get the lengths you may need. But yes, the biggest factor is what can you get from Ebay.
    I've gotten 2 pairs of 26" long 15mm IKO's that I plan to butt end to end to make a 48" wide gantry. $130 for 4 rails and 8 blocks. And a pair of 18" 15mm THK's with 4 blocks, $40. And about 6 months of waiting on Ebay 'til they showed up.
    Jan 2006
    92
    I just decided to search for rails again after not looking for a while and ended up with two 22.5 inch 2omm thk rails with two blocks each for 25 bucks, they are in excellent condition. I was lucky to find them, they didn't say thk or anything in the title, but the blocks say it I was stoked.
    Jul 2006
    1256
    I dont know what static and dynamic loads are or how to calculate required rail size.A friend recently purchased a5x10 Thermwood router.The rails are 20mm.The machine weights 8000 lbs I guess the gantry must be 3000 at least {10 Hp spindle and auto tool changer} Now I know 20mm rails are overkill for a DiY CnC .
    Larry
    Feb 2004
    1086
    Moment loads...
    One thing to keep in mind is that while these bearing rails are in fact very sturdy, the main loading you need to concern yourself with often is not the static or dynamic load, but the moment load. Particularly on the rails on a moving gantry, if you have a tall Z axis, there is a significant lever arm acting on your bearings. Under large cutting forces, with a long Z axis, you could exceed the allowable moment load of some of the "wimpier" rails.
    This is not to say that any of the previous comments have been wrong -- most of the rails out there are super strong, and are more than adequate for DIY, especially for the rails supporting the gantry. However, moment loads should be considered, and are fairly easy to calculate "back of the envelope". Force X Distance. I usually use a higher number than I think I'll actually see, like 300 lbs. of force on my spindle, to make sure everything is beefy enough.
    Jan 2021
    Re: What size THK/Hiwin rails and blocks?
    Would not a bigger rail add to the mass of the system. Like using a 400x300x20 mm steel table on 25 size rails would give less chatter (or something else) than with size 15 rails?
    15362
    Quote Originally Posted by gnindit View Post
    A little late to the party this thread is from 2006 that's 15 years ago, a lot has changed in that time, but 15mm rails are still a good option for small size machines
    Mactec54
    Jul 2018
    6339
    Hi GN - Rails and cars come in different accuracy classes, different car styles and preloads. If you pick the right one for the application they won't chatter. Often rails and cars are choosen via its package size vs its strength. The static strength of the car is the load at which permanent damage is done to the car. The dynamic strength allows the designer to calculate the life of the bearing in its service conditions. With CNC machines they can also be selected for their stiffness, the bigger rails are stiffer then the smaller rails. All discussed in below doc. Peter
    https://www.hiwin.tw/download/tech_d...ideway-(E).pdf
  1. Grease fittings for Hiwin 20mm blocks
    By escott76 in forum Linear and Rotary Motion
    Last Post: 04-30-2009, 03:40 AM
  2. need hiwin cad files for old ag series rail and blocks
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 03-11-2008, 02:36 AM
  3. hiwin guide blocks and rails
    By eloid in forum Linear and Rotary Motion
    Last Post: 12-10-2007, 12:46 PM
