586,071 active members*
3,920 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > sounds in gibbs cam
    1880
    sounds in gibbs cam
    anyone know if its possible to turn the sounds off in gibbs cam?
    I use my computer for multiple things and need the sound up pretty high and its very annoying to have it ping a noise every time i post a file or other widget.
    thanks
    Michael
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    15362
    miljnor
    Have been using Gibbs for more than 15 years, & have never had any noise's from it like you are having, It must be some setup you have with your computer
    Mactec54
    15362
    miljnor
    Just had to have a look at mine, Go to control panel, Sounds, you will find some settings under Sounds I have None set on mine, so all the startup beeps /dings Etc will be gone if you uncheck them all, this may be different depending on what system you are using
    Mactec54
    1880
    Thanks mactec54 that did it.
    When I installed an new video card I guess it turned all that crap back on.
    thanks
    Michael T.
  1. Sounds of machines
    By bunalmis in forum Stepper Motors / Drives
    Last Post: 03-31-2021, 05:05 PM
  2. play sounds
    By daniellyall in forum Mach Wizards, Macros, & Addons
    Last Post: 03-08-2013, 10:18 AM
  3. What sounds like Racking but its not!
    By restless1 in forum Linear and Rotary Motion
    Last Post: 07-14-2011, 12:25 AM
  4. This sounds odd to me...
    By Eritex Inc. in forum Haas Mills
    Last Post: 02-03-2011, 08:41 PM
  5. Wolfgang motor sounds bad
    By frejohg in forum PCB milling
    Last Post: 06-13-2010, 10:22 AM
