586,080 active members*
3,737 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Sprial Cut - Can I do it in BobCad
Results 1 to 6 of 6
    Jun 2006
    143
    I need to cut a circular hole out of a part. I was hoping to be able to do a sprial cut downward into the part. Is there a G-code for this and if there is how can I get bobcad to program it for me?
    Using V20 of bobcad and techno CNC router.
    Mar 2006
    1625
    yes look in the other menu on main tool bar sprial/pipe thread
    Aug 2005
    300
    Spiral
    Why not try pocketing and use the spiral cut option?
    ErnieD
    Mar 2006
    1625
    pocket function will do moves in two planes only, not a 3 axis move attach is sample file of sprial down
    Attached Files Attached Files
    Nov 2004
    26
    Milling a 1" hole in 1" 6061
    What is the best way to do this. I understand the sprial/pipe option. It is ok but is there any way to have it pick the center of the hole and have it start there? Rather than finding the center and telling it. I draw in autocad and use 20 for CAM
    Gary
    Jan 2006
    4396
    Quote Originally Posted by gguidi
    Gary
    Yes, do a spiral and put a point at the bottom end of the entity. Use the pocketing function in the Other Menu. Locate the Start point (line indicating start green). Place a point at the bottom. Select the spiral using the Shift Key on your Keyboard. Goto the Change Menu>Translate>Snap>OK. Now select the bottom point of your Spiral and the Start point of your Green starting postion of your pocket.
    Sorry I forgot the Cad file.
    As a Big Plus BCC has a Support Forum at http://216.117.147.20/bobcadsupport/forums/index.php
    :cheers:
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
