I need to cut a circular hole out of a part. I was hoping to be able to do a sprial cut downward into the part. Is there a G-code for this and if there is how can I get bobcad to program it for me?
What is the best way to do this. I understand the sprial/pipe option. It is ok but is there any way to have it pick the center of the hole and have it start there? Rather than finding the center and telling it. I draw in autocad and use 20 for CAM
Gary
Yes, do a spiral and put a point at the bottom end of the entity. Use the pocketing function in the Other Menu. Locate the Start point (line indicating start green). Place a point at the bottom. Select the spiral using the Shift Key on your Keyboard. Goto the Change Menu>Translate>Snap>OK. Now select the bottom point of your Spiral and the Start point of your Green starting postion of your pocket.
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
