Hello,
I´ll be using this motor:
motors
I´ll appreciate if someone could help me put some instructions to build the power supply to drive this servos.
I want to have plenty of power to drive 6 of them...so...
1. The terminal voltage is 60VDC, constant current 3.7A and a peak current of 25.9A for this servos as the posted spec sheet tells...
2. What voltage is the best to drive the motors, should i drive them at 100%, 90% 80% of the terminal voltage? how can i know the best voltage to drive them?
3. After knowing the voltage, i guess i need the amp needed, so i know there has to be 6 times something, as i want to have power for 6 motors, which amperage should i use, the constant current in the specs times 6? should i allow a safety factor?
4. Knowing the voltage and amp needed in the power supply...next i need to calculate the transformer voltage (VAC), how do i do this?
5. Knowing the transformer voltage (VAC) i have to calculate the transformer current and volt amp (VA) rating, so.. how i do this? and should i consider a safety factor?
6. Guess i can choose a toroid transformer now?
7. How do i calculate the capacitor and the bidge?
Best Regards,
Hector
