586,477 active members*
3,781 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Newbie question: How to alter toolpath
    Jan 2014
    14
    I'm facing off my part and want my next operation (roughing the profile) to start right after the face, but instead the tool backs up a bit in Z+ before making the cut. I've messed with the lead-in, changing the Entry Vector settings, but to no avail.
    Apr 2011
    95
    You might be able to change your safe height
    Sent from my GT-I9505 using Tapatalk
    Jul 2003
    263
    the tool will retract to the clearance plane between operations in mastercam. as far as i know you cannot force the tool to stay down between operations. if you know you are not going to hit then you can set your feed plane about -.05 ( absolute ) below the final depth and the tool will rapid to the depth instead of feeding in to depth in the Z.
    If you can ENVISION it I can make it
  1. How to alter #1000 variables
    By hydrospin01 in forum Fanuc
    Last Post: 01-05-2011, 08:35 AM
  2. why does mach3 alter my gcode?
    By turbothis in forum Mach Software (ArtSoft software)
    Last Post: 10-17-2010, 11:08 PM
  3. Newbie help w/ Profile toolpath
    By EndIsForever in forum Rhinocam
    Last Post: 10-03-2009, 05:43 PM
  4. Replies: 6
    Last Post: 12-19-2008, 11:23 PM
  5. MC9 mill toolpath in lathe-newbie question
    By scolee in forum Mastercam
    Last Post: 08-15-2007, 10:02 PM
