586,069 active members*
3,814 visitors online*
Thread: HURCO VM20
    Feb 2014
    HURCO VM20
    I work with a Hurco VM20. I am trying to replace the air filter/regulator on my machine and found out that it is on back order. Does anyone know of a replacement part that can be used instead of using the part from the manufacturer?
    Oct 2004
    188
    Look at the regulator it should be SMC type the part numbers in to google. Should be able to find it there.
    Allied electronics carries a lot of the SMC stuff
    Jun 2008
    1104
    Or you could fit any FRL unit with 3/8 BSP ports.
  1. HURCO VM20 - NC PROGRAMS OVER RUNNING
    By NPE Ltd in forum Drilling- and Milling Machines
    Last Post: 01-10-2013, 12:56 PM
  2. Doosan DNM 400 or Hurco VM20 ?
    By Grimreaper831 in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2012, 01:15 PM
  3. Hurco VM20 Winmax post?
    By jolson89 in forum GibbsCAM
    Last Post: 03-24-2012, 02:58 PM
  4. hurco vm20
    By maximas101 in forum HURCO
    Last Post: 12-03-2010, 04:59 AM
  5. Hurco VM20 ???
    By nevron in forum HURCO
    Last Post: 08-22-2009, 06:53 AM
