Alibre Assembly to DXF file
I like to make cabinetry and furniture from time to time and often cut the parts on my cnc router. I use Alibre PE to draw alot of the "boxes" with the shelf holes, hinge holes, dados, etc. Currently I export each part to dxf file format and manually nest them before cutting.
I have seen several packages for solidworks that will take an assembly and export to dxf. Does anyone know of a reasonably priced addon for Alibre that will do the same thing?
Dan
Check out what I am working on at www.routerbitz.com!
