586,115 active members*
3,432 visitors online*
    Aug 2011
    27
    lathe SQT-28M, T PLUS MAZATROL control.
    Hello.
    I have a problem with a lathe SQT-28M, T PLUS MAZATROL control.
    The battery is depleted.
    I have reset according to the manual, loaded the machine parameters, tool data, offset, cutting conditions, conditions of material, data plate ... etc.
    problem:
    When I run the program in automatic stays in standby mode in the initial cutoff and as much as I press the start key cycle, the system will not work. The spindle is rotating at a low speed.
    You could tell me that it could be happening?
    Could you send me some information to solve this problem.
    Best regards.
    Apr 2006
    3206
    Is the door closed?
    Aug 2011
    27
    No, This open, but we are running the program block by block (pressing start cycle). The display shows that the block moves only 1 to 5.
    Sep 2008
    93
    antes de que la bateria fallara no tenias este problema ?
    asegurate hacer la prueba con puerta cerrada, y haz pruebas con otros programas, si hace lo mismo con los otros programas, entonces suguiero reinizializar el control numerico.
    tengo el procedimiento por si lo requieres.
    saludos
    Aug 2011
    27
    Hola mantenim.
    No teníamos ese problema, nosotros ya reiniciamos el control, pero aun así sigue el problema.
    Podrías enviarnos el procedimiento y las consideraciones a tomar?
    Te dejo mi correo: [email protected]
    Saludos cordiales.
  1. Mazak Quick Turn Nexus 200 lathe with Mazatrol 640 T-Nexus control
    By arwinder in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-15-2015, 04:50 PM
  2. Mazak VQC-15/40 With Mazatrol CAM M-2 Control
    By bob1371 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-18-2014, 03:58 PM
  3. MAzatrol T32B Control
    By davidblair in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-26-2010, 05:28 PM
  4. Mazatrol Cam M2 Control
    By empireweld in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-02-2009, 05:58 AM
  5. mazatrol control
    By Fraggle in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-04-2006, 11:58 PM
