Can anyone provide the diameter of the leveling feet on the deluxe stand for the 1100? Trying to plan ahead for my installation and have appropriate material for leveling available.
Brian
Brian
The leveling feet screw in and out to aid in leveling the base!
Otherwise they are about 4" in diameter.
If you thinking about wood cribbing under base during install or placement. The shipping crates it arrives in provides plenty of blocking or shimming for placement.
Hope this helps
Md
Thanks, my floor has quite a bit of slope so I thought it might be better to shim the whole thing up with a piece of plate steel, instead of crank the leveler way out
B
I recently moved my machine to a garage floor with a slope and had to address the same issue. I used a level to gauge how much I needed to raise the low side. I used big steel washers with a hole just bigger than the stud. They are between the frame and the foot. I put them on (3 per foot, as I recall) and screwed the foot back in to put the load on the washers and not so much on the threaded stud. The level was spot on in my case. I was going to make the spacer, but the lathe was not unpacked at the time and the washers did the job.
