586,076 active members*
3,702 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > MORI SEIKI NL3000- TURRET INDEXING ISSUE
    Dec 2013
    While changing the back-up battery the panel was powered down. We have taken care of all of the alarms. We performed T-axis 0 procedure. The problem we are having now is that when the turret is indexing, at the end of the index is jumps slightly and we hear a clang from the clamp. How can we fix this issue? Any input will be appreciated.
    Thanks in advance.
    Dec 2013
    I need a procedure to line up the turret clamp, I belive it is just a hair off.
    Anyone who has powered off the control panel on a Mori Seiki NL 3000 while changing the backup battery should have encountered the same problems we are having. Anybody that has any experience with this please provide some input.
    Thanks.
    Aug 2011
    2517
    a simple search for 'mori turret zero' returns several posts relating to the subject including.....
    http://www.cnczone.com/forums/mori-s...et-homing.html
    http://www.cnczone.com/forums/mori-s...ret-issue.html
    Jan 2013
    7
    You must set some Data (PC-PRM) to activate Turret Adjust Mode (please find them in the Ladder Diagram manual).
    This Data are different from machine model to another.
    Data are "double paramenter" and must be activate with "maintenance procedure" Feed Hold+Edit Key Off/On
    Then while pressing Turret + or Turret - you can Clamp/Unclamp Turret.
    Then select Handle and select T in the axis selection
    Totare turret nearest to the n.1 cutting position (a bit in advance respect tte exact position).
    Then select ZRN mode
    Then keep press Turret Index (turret will rotate a lil bit then stop).
    ZRN procedure is done.
    Power Off/On and in manual mode rotate the turret and check.
    Feb 2009
    6028
    With the mits its a little tricky.
    Sent from my G-Tab Quantum using Tapatalk
  1. Mori Seiki SL603CMC/3000 Turret issue
    By WECtech in forum Mori Seiki lathes
    Last Post: 06-02-2017, 03:53 AM
  2. MORI SEIKI NL3000
    By christian59 in forum Mori Seiki Mills
    Last Post: 02-17-2014, 04:55 PM
  3. MORI SEIKI SL-25B TURRET INDEXING PROBLEM FANUC OT
    By ROHAN 1981 in forum Community Club House
    Last Post: 02-03-2014, 03:47 PM
  4. Mori AL-2 Turret Indexing and X Home Problem
    By krfrea in forum Mori Seiki lathes
    Last Post: 01-03-2011, 07:59 PM
  5. Mori Seiki NL3000 Gone Wild
    By joseavina76 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-06-2007, 09:40 PM
