586,060 active members*
4,521 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Q tool presetter problem PUMA 240L
Results 1 to 17 of 17
    Oct 2012
    25
    Hi every body.
    We have a problem with our PUMA 240L machine's quick tool presetter as flow:
    we do all according to its user manual. when tool touches the probe, the red lamp in probe center will be ON but the axis movement will not stop.
    thank you for any ideas and helps.
    2932
    Has the Q-Setter worked prior to this?
    Oct 2012
    25
    Hi.
    thanks for your attention.
    yes, it has worked before, but with error in X direction ( i think it just needed calibration) but they tried to repair it ... and now this is it's situation !!! ( i don't know they tried on controller or any thing else) .
    by the way this machine had a crash on it's turret and has repaired.
    thank you very much.
    2932
    It sounds like maybe the wiring for the X+, X- may be wrong. I've seen that happen before. Does Z-axis work OK?
    Oct 2012
    25
    X and Z work in all modes.
    but the problem is with Q-Setter.
    none of them wont stop when touch the probe.
    older operators in our company told me : it had worked before, but the X tool-offset was not accurately. ( calibration needed )
    Thanks for your attention.
    2932
    Quote Originally Posted by ekashfi View Post
    1. Does the display change to the geometry offset page when the q-setter is lowered into position?
    2. Is the Keep Relay that selects whether the q-setter is used "ON" (There should be a blue book in the electrical panel listing all of the keep relays)?
    3. Have you checked the diagnostic inputs from the 4 pads (the electrical diagram I have list X4.2 - X4.5... your machine may be different)?
    Oct 2012
    25
    1. yes it doe's. the display change to offset page with the cursor on the active tool. (parameter 5005.#5 is 1)
    2. yes. keep relay K7.5 is 1 ,it means Q-setter is attached to the machine. and also K6.3 is 0 that it means manual type of Q-setter is not attached to the machine. i had changed this one(K6.3) to 0 once, but there was no difference with before.
    3. how can i check the diagnostic input from the 4 pad.
    Aug 2008
    151
    Pumas are prone to coolant contamination in the area where the Q switch attaches to the arm. Sometimes the wire breaks where the arm attaches to the machine, since that is where it bends the most. Checking the X diagnostics is a good idea. You'll need to find out which X input on the diagnostics is assigned to each switch from the electrical or ladder documentation.
    Warren
    Uptime Electronics, Inc.
    Oct 2012
    25
    Hi.
    i checked out the ladder and electrical manual. mine either. X4.2 for +MT1.M , x4.3 for -MT1.M , X4.4 for +MT2.M , and X4.5 for -MT2.M.
    but now i don't know how to check it on the machine. how can i access on diagnostics ?
    Thanks for attentions.
    Regards.
    Aug 2008
    151
    Here's a picture of the screen you want. Press this button until the Diagnostics screen appears. Then, look for the X0004 line.
    Good luck,
    Warren
    Uptime Electronics, Inc.Attachment 225472
    Oct 2012
    25
    thanks for your kindly guidance.
    i could find it.
    now i think i must touch the probe in X+ , X- , Z+ and Z- . and check the changes in X4 line.
    is it right?
    Aug 2008
    151
    Yes.
    Oct 2012
    25
    when the tool tip touch the probe, none of x4.2 - x4.5 changes. all of them remain zero.
    but some other parameter, that i checked, in the status of pmc parameter change as they should.
    so is the problem in wiring of Q-setter?
    what we have to do?
    Regards.
    Aug 2008
    151
    It is unlikely that all four switches failed together. I would have someone check the wiring at the joint where it flexes the most, where the arm attaches to the machine. That is a common place for the wires to break.
    Warren
    Oct 2012
    25
    OK i will check that. but when the tool touch the probe, the red lamp on center of probe turn on. doe's this lamp turn on if the wire is broken?
    Oct 2012
    25
    Hi.
    first I have to correct my previus post.
    only the X+ change on PMC status. but none of the others.
    on the interface board there are 4 LED that any one of them shows a signal received from the probe.
    3 of the turn on when touch , but 1 of them that is X- will not turn on.
    here is the interface board.
    i gave it to our electrical department for investigations.
    Attachment 225914
    Attachment 225916
    regards.
    Oct 2012
    25
    PUMA 240L turret backlash
    I appreciate all responses.
    the q-setter interface board is under repair.
    but now we have another problem with the turret.
    After tool change the turret turn about 5deg backward. and the backward turn is different for each station. this make it impossible to use Q-setter in the X direction.
    Regards.
  1. DMG Eco 210 Tool Presetter
    By Johann Hogan in forum Calibration / Measurement
    Last Post: 03-13-2014, 02:53 AM
  2. Puma 240L
    By positiverake in forum Daewoo/Doosan
    Last Post: 02-21-2014, 10:57 PM
  3. tool presetter
    By shredder in forum MetalWork Discussion
    Last Post: 12-23-2013, 01:31 PM
  4. No tool presetter
    By gbpacker in forum Fadal
    Last Post: 01-09-2010, 04:18 AM
  5. Tool Presetter
    By norzadeug in forum Calibration / Measurement
    Last Post: 02-07-2008, 08:58 PM
